Regulator Help
Chad
Oct 3, 2017
35
33
Seaside, Oregon
I purchased a Airgas Y12-244A regulator off of the auction site for $25 before doing much research.
I know I will need a cga nut/nipple and a solenoid.
Couple questions.
Is this a dual stage regulator?
Is 30 psi enough working pressure for a ceramic diffuser?
Does this needle valve seem sufficient?
I will need to get a solenoid. I was looking at the post body kits from diyco2reg but they all include a needle valve. Can I just get a reducer and the solenoid and just piece it together from there?
<3 Chad
Phishless
1,103
972
Arnold, MD
Dual stage yes according to web browse.
30PSI depends on ceramic diffuser.
Higher PSI and needle valves get picky.
Would purchase a nipple and solenoid and mount before needle valve.
Hope this helps.
Chad
Oct 3, 2017
35
33
Seaside, Oregon
I didnt realize from the picture that the left gauge is a little smashed. Hopefully the regulator will still work. I guess the next step is to install the cga nipple and give it a test.
Fish Out of H2O
Jun 3, 2018
21
6
Eugene, OR
At a glance, both gauges are not at zero, which COULD be a sign of internal damage. From experience, I would first perform leak down testing before you buy any parts for the build. Add the CGA320 nut and nipple and do this:
http://www.plantedtank.net/forums/9...ck-co2-pressurized-system.html#/topics/137245
If it passes, then build out. Last, I suspect that needle valve will not allow for fine bubble tuning.
Best of luck in the build!
