Regulator Build Links
Discussion in 'CO2 Enrichment' started by Gerryd, Feb 6, 2011.
  1. Gerryd
    Gerryd Plant Guru Team
    Sep 23, 2007
    5:45 PM
    Hi all,
    I though I would make this a sticky as these links contains loads of great info and how-to instructions with pictures.
    How to build a Victor VTS 253A-1993:
    http://www.barrreport.com/showthread.php/7787-How-to-build-a-Victor-VTS253a-1993
    How to wire your own Burkert type 6011 solenoid:
    http://www.barrreport.com/showthread.php/7783-How-to-wire-a-Burkert-type-6011-solenoid
    How to install a CGA 320 on a used Victor HPT 500:
    http://www.barrreport.com/showthread.php/7786-How-to-change-a-CGA-on-a-used-regulator
    How to prep a used Victor HPT270 for a post body kit:
    http://www.barrreport.com/showthread.php/7788-How-to-prep-an-Victor-HPT-270-for-a-post-body
    Why gas flow direction is important when installing a Burkert solenoid:
    http://www.barrreport.com/showthread.php/7864-Burkert-Solenoids-gas-flow-direction-is-important-in-preventing-leaks
    How to build a Victor SGT 500: (90* output regulator)
    http://www.barrreport.com/showthread.php/7879-How-to-build-a-Victor-SGT-500-Regulator
    Happy reading.
    How to adjust your Ideal Valve:
    http://www.barrreport.com/showthread.php/7971-How-to-adjust-your-Ideal-Valve
    How to use Swagelok Tube Fittings:
    http://www.barrreport.com/showthread.php/8226-How-to-use-Swagelok-tube-fittings
    DSR: Total Conversion From JBJ BUbble Counter to Swagelok Tube Adapter:
    http://www.barrreport.com/showthread.php/8227-DSR-Total-Conversion-from-JBJ-bubble-counter-to-Swagelok-Tube-Fitting
  2. barbarossa4122
    barbarossa4122 Guru Class Expert
    Dec 29, 2009
    975
    5:45 PM
    Thanks Gerry. The links are working:)
  3. Matt F.
    May 30, 2009
    2,319
    5:45 PM
    Here is an updated list of DIY links:
    How to build a VTS253B-320:
    http://www.barrreport.com/showthread.php/7785-How-to-build-a-Victor-VTS253b-320
    Happy reading.
    Gerryd's DSR Build:
    http://www.barrreport.com/showthread.php/8190-Gerryd-s-regulator-build-thread
    Swagelok part numbers for two regulator configurations (regulator to tube adaper):
    http://www.barrreport.com/showthread.php/8332-Basic-Swagelok-Parts-needed-for-90*-and-VTS-Builds?p=62668#post62668
    How to build an SGT 500 (2):
    http://www.barrreport.com/showthread.php/8516-How-to-Build-an-SGT-500-(2)?p=64375#post64375
    Rainydazs' regulator build (GPT270):
    http://www.barrreport.com/showthread.php/8538-rainydazs-s-Regulator-Build
    Samuel's VTS252D-350 Build:
    http://www.barrreport.com/showthread.php/8595-Samuel-s-VTS252D-350-Build?p=65021#post65021
    My two SGT500s:
    http://www.barrreport.com/showthread.php/8632-My-two-SGT500s-(thanks-to-Left-C)
    Regulator Body Thickness?
    http://www.barrreport.com/showthread.php/8671-Regulator-Body-Thickness?p=65564#post65564
    Conversion from Swagelok tube adapter SS-6M0-1-2 (male) to SS-6M0-7-2 (female):
    http://www.barrreport.com/showthread.php/9103-Conversion-from-Swagelok-SS-6M0-1-2-(male-NPT)-to-SS-6M0-7-2-(female-NPT)?p=72227#post72227
    Where to buy CGA NUTS NIPPLES AND FILTERS for your DIY project:
    http://www.barrreport.com/showthread.php/9964-Where-to-buy-CGA-nuts-nipples-(stems)-and-filters-onliine-for-your-DIY-projects
    Swagelok's online pipe fitting catalog with pictures!
    http://www.barrreport.com/showthread.php/9867-DIYers-Swagelok-s-Pipe-Fitting-Catalog?p=80678#post80678
    Updated tube adapters on my SGT500s:
    #3 Matt F., Apr 27, 2011
  4. Matt F.
    May 30, 2009
    2,319
    5:45 PM
  5. Matt F.
    May 30, 2009
    2,319
    5:45 PM
  6. Matt F.
    May 30, 2009
    2,319
    5:45 PM
