Reflector for t-8
Discussion in 'General Plant Topics' started by Brian20, Mar 4, 2010.
  1. Brian20
    Brian20 Guest
    6:03 AM
    Hi, I dont know if this thread can be put here. Well I like to put clip on reflector to t-8 tubes, I dont have a lot of space for big reflectors. My big concern is that this reflectors will works, they touch the tube so it have internally reflection, This really works or only use flat reflector in the canopy?
  2. pat w
    pat w Member
    Nov 4, 2009
    462
    12:03 PM
    Do you have a photo for reference? What is the shape? (parabolic, or somthing like the type at AH Supply) Hard to say without knowing the relative positions of the center of the tube and the focus of the reflector.
    Pat
  3. Brian20
    Brian20 Guest
    6:03 AM
  4. pat w
    pat w Member
    Nov 4, 2009
    462
    12:03 PM
    Yeah, they should perform better than a flat reflector. The key would be to minimze the amount of the reflected light that has to be reflected 2 or more times to make it to the tank. Each reflection will lose a little energy in the process, how much is determined by the quality of the reflector surface.
    Did a quick search and found this.
    http://www.awi-industries.com/OPTICS_reflector.html
    Hope it helps.
    Pat
  5. Brian20
    Brian20 Guest
    6:03 AM
    like precalculus parabola :D
  6. Brian20
    Brian20 Guest
    6:03 AM
    looking and looking and no shipping for PR :(
  7. pat w
    pat w Member
    Nov 4, 2009
    462
    12:03 PM
