Biollante;58569 said:
Easiest, cheapest source of Nitrite for average folk would be home meat curing product such as Speed Cure, InstaCure, or Quick Cure.
Supurb, my only problem is that I've never heards of those products over this side of the pond - I'll have to keep my eyes open for similar and check ingredients.
When I had to busk the Ammonia instructions, this is what I came up with (borrowing a few words from Left C at the end ;-) My only issue is that I'm now not 100% certain whether the quantity of water in step 2 should be 475ml or 470ml (the 5 coming from the Household Ammonia) - I suspect 470, but the concentration difference is pretty much irrelevant anyway).
1) Go to Homebase (other sources of Ammonia are available) and buy some 9.5% 'Household Ammonia' solution (make sure whatever you buy doesn't have scent or detergent in it). This is the same stuff you can use to 'fishless cycle' a tank.
2) Measure out 475ml of distilled or deionised water (from Halfords or a hardware store or LFS RO water) using a measuring cylinder (you can get one from a home brew shop). A rougher way of doing this is to put a bowl onto an accurate kitchen scale, zero the reading and then pour in 475g of your water.
3) Using a children's medicine dosing syringe (any good pharmacist) measure out precisely 5ml of the household Ammonia and add this to the water. This gives you a 1000ppm stock solution.
4) Add 1 ml of the 1000 ppm solution to 9 ml of distilled water. This makes 10 ml of a 100 ppm solution.
5) Add 2 ml of the 100 ppm solution to 18 ml of distilled water. This makes 20 ml of a 10 ppm solution.
Then, as needed:
6) Add 1 ml of the 10 ppm solution to 99 ml of distilled water. This makes 100 ml of a 0.1 ppm solution.
7) Add 1 ml of the 10 ppm solution to 49 ml of distilled water. This makes 50 ml of a 0.2 ppm solution.
8) Add 1 ml of the 10 ppm solution to 19 ml of distilled water. This makes 20 ml of a 0.5 ppm solution.
9) Add 1 ml of the 10 ppm solution to 9 ml of distilled water. This makes 10 ml of a 1.0 ppm solution.
10) Add 2 ml of the 10 ppm solution to 8 ml of distilled water. This makes 10 ml of a 2.0 ppm solution.
11) Add 3 ml of the 10 ppm solution to 7 ml of distilled water. This makes 10 ml of a 3.0 ppm solution.
12) Add 4 ml of the 10 ppm solution to 6 ml of distilled water. This makes 10 ml of a 4.0 ppm solution.
13) Add 5 ml of the 10 ppm solution to 5 ml of distilled water. This makes 10 ml of a 5.0 ppm solution.
Peter
