Recommended species for freshwater refugium without substrate
Discussion in 'Aquatic Plant Species' started by evangemeren, Mar 4, 2014.
  1. evangemeren
    evangemeren Junior Poster
    Oct 5, 2013
    19
    6:26 AM
    Hi all!
    I am trying to find a good plant species to use in a freshwater refugium. I am looking for a species that does not require substrate (can be left free-floating in refugium or simply weighted down/tied to rock), and that does a good job absorbing large amounts of nutrients from the water column. Refugium passes relatively large amount of water (450 gph), so looking for a species that doesn't mind water flow.
    I have dedicated Aquaray GroBeam LED (6500K) on the refugium, and direct CO2 injection (diffuser in refugium).
    The refugium is an Aqueon ProFlex Model II, in case that matters.
    Water conditions:
    - 78 degrees F
    - 9 dGH
    - 5 dKH
    - 7 pH
    I am currently using hornwort, but having difficulties keeping it alive, as I have been advised that the flow rate is too high, so I am looking for alternatives.
    Any suggestions would be appreciated!
  2. AaronT
    AaronT Member
    Jul 29, 2013
    195
    6:26 AM
    Water sprite. Get ready to throw it out by the pound. :)
  3. Farmhand
    Farmhand Prolific Poster
    Apr 7, 2010
    46
    10:26 PM
    I'm working on a similar idea and was thinking using floaters in a sump, which would not work for you with high current. Curious how this works out for you.
  4. Tom Barr
    18,694
    731
    6:26 AM
    Floating plants are the best, or emergent plants.
  5. evangemeren
    Oct 5, 2013
    19
    6:26 AM
    Thanks, Tom ... is there one or two in particular you would recommend for high flow refugium?
