Recommendations for a water circulation pump in an Eheim Aquastyle 35L cube
Discussion in 'General Plant Topics' started by Rhizomorph, Feb 25, 2015.
  1. Rhizomorph
    Rhizomorph Junior Poster
    Feb 24, 2015
    14
    6:37 PM
    Hello All,
    Can anyone recommend a circulation pump for a 35L Eheim Aquastyle planted tank - it has an internal Eheim filter but because of the way the outlet of this filter is angled much of the flow dissipates rapidly. It claims to do 200L/h -- but suspect when the filter gets a bit grimy it's going to be much less than this.
    I've tried a Koralia Nano 900L/h (240G/h) -- but its pretty strong in this little tank (moving 900L per hour as it does). Does anyone have recommendations for circulation pumps for these smaller tanks that aren't going to blow my plants around like it's a rapids biotope :) .
    Ty in advance! :) -- Rhizomorph.
  2. shoggoth43
    shoggoth43 Lifetime Charter Member
    Jan 15, 2009
    6:37 PM
    Maybe restrict the output on the Koralia by blocking off some of the inlet holes?
    I'm guessing this won't be a CO2 heavy tank so maybe some old school low tech options? Air stone? Air lift? Ditch the Eheim filter in favor of an air driven sponge?
