I have a CarbonDoser EXT5000 external reactor and at first I was in love because the design seems as if it's perfect but it turns out I can't get it to deliver. It's powered by an Eheim 2215 exhaust and has a self contained Rio pump (Rio 90 ?? maybe) and the way it works is the gas and water enter the top of the housing, the pump rests on the bottom pulling the mixture up a tube and out to the tank, half way up there is a coarse pad that will break up the gas and not allow it to pass if undisolved.
It really works very well but if you get the bubble count too high the gas will start to push all the water out of the housing. I was hoping you could help me figure out how to make it work as it should and I was thinking the Needle wheel DIY modifications might work on this unit, I have only seen the modifications to the impeller and never a completed unit (a lot of photos are missing and some links are broken) that you guys are using. Any help you can offer would be greatly appreciated.
BTW I plan to make a call to the manufacturer as this unit is rated for tanks up to 1000 gallons but I'm having problems on a 150, I will update any progress to help others with the same unit.
