Ramosior And The Droop
Jun 1, 2020
30
Chicago
Chicago's_PlantedTank submitted a new Article:
I’d Like to first start off by simply saying that this was just an experiment that I decided to test out. I have only been in the hobby for about 1 year and 7 months: Take this info as you wish. I am not claiming this to be a solution of any sort, there are people that have been around a lot longer than I have that might have a better hypothesis. When I first began to put thought into this I thought to myself...
Read more about this article here...
18,696
745
Ethylene is often associated with rapid necrosis. The strong central stele is the the xylem/collenchyma, the outer softer pithy sponge like material is the ground tissue, and it's where the aernychyma is and what facilitates gas exchange.
It's wise to use this honeycomb type of structure to reduce the need for extra tissues since there's no need to fight gravity much in the submersed state. Cutting off the source of gases like endogenous ethylene is likely what's going on here. It also removes the O2 being sent to the roots.
In my own experiences, trimming often led to MORE necrosis, whereas NOT trimming led to continued prolonged growth. Aggressive trimming did not work so well in my case.
I did not lose all the plants, I lost maybe 40-60%. This was in 3 different tanks. Nutrients where never a factor. Tank height was different. Possible factor. Sediment was the same, old ADA AS, current: pretty wide ranges, no response.
Higher KH seems to mitigate the effect.
This was not for Florida, only the normal types Rotala sunset.
I've not had issues with "Florida".
