I recently converted a 20H co2 tank with 48 watss of t5 lighting to an excel tank.
I took out one bulb leaving me with 1.2 wpg. Is this on the low side for an excel tank ?
If I used 2 bulbs and raised the fixture I could get more light and better coverage .
If I use the inverse square law will this give me a ballpark idea of how high to raise the lights ? I believe the inverse square law applies to a point of light and assumes light is traveling through air rather than water and tank lids.
Can I use this approach as a start point to calculate how much to raise the lights or is there some other better method ? If 1.2 wpg of T5 lighting is adequate then maybe it's not worth the bother and wasted light.
I .
I .
