Raise KH or add more CO2 and lower pH
Discussion in 'CO2 Enrichment' started by tecapparatus, Jun 4, 2015.
  1. tecapparatus
    tecapparatus Subscriber
    Dec 30, 2011
    12
    4:46 PM
    My tap water is ~2 dKH and similar in my tank. I have my CO2 addition /pH set to 6.5 pH. I would like to raise my overall CO2 ppm. Better to raise KH (would have to do every WC) or lower pH down to 6.2/6.3 to get to 30-40 ppm CO2?
  2. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    4:46 PM
    No need to worry about the pH drop. 6.2-3 is fine.
