Quick needle valve Q
Discussion in 'CO2 Enrichment' started by abcemorse, Oct 22, 2010.
  1. abcemorse
    abcemorse Prolific Poster
    Sep 8, 2008
    83
    4:22 PM
    Does the Ideal needle valve fit the Milwaukee rig or do I need bushings?
  2. Left C
    Left C Lifetime Members
    Sep 26, 2005
    2,500
    4:22 PM
    You will need some brass fittings.
    I don't own a Milwaukee regulator, but I have several Ideal 52-1-12 needle valves. They have female 1/8" NPT ports on each end which require male 1/8" NPT adapters at each end. The safe way to set it up is to use a 1/8" NPT check valve between the Milwaukee bubble counter and the Ideal needle valve. Between the solenoid and the Ideal needle valve, you can use a 1/8" NPT hex nipple. You can get one at Lowes, Home Depot or a plumbing supply.
    These are the ones at Lowes and Home Depot made by WATTS:
    [​IMG]
    No. 122 Hex Nipple
    122-2
    1⁄8" MIP Both Ends
    A-714
    You can get a male 1/8" NPT check valve from Clippard, Swagelok, Parker, eBay, etc. Get a low cracking pressure check valve.
    This wouldn't be my first choice, but it will work. Here is an eBay Clippard female 1/8" NPT check valve with a 1/2 psig cracking pressure. If you get this, you will need 3 of the 1/8" NPT hex nipples. Two will go on each side of the check valve and one will go between the solenoid and Ideal needle valve.
    http://cgi.ebay.com/Clippard-Minimatics-MJCV-1-Brass-1-8-CHECK-VALVE-/360309581155?pt=Pneumatic_Hydraulic_Valves_Parts&hash=item53e41fe563
    [​IMG]
    [​IMG]
  3. Matt F.
    May 30, 2009
    2,319
    4:22 PM
    my guess is you'd prob need a new jbj bubble counter, too. The nipple outlet for the gas in that milwaukee bubble counter is conneceted to the needle valve. You remove the needle valve and you have a gaping hole...no fine bubbles just a lump of gas escaping into the bubble counter from the new 1/8"npt fitting and the idea valve...
  4. darkoon
    darkoon Prolific Poster
    Jul 12, 2010
    81
    4:22 PM
    I retrofitted Milwaukee setup by swapping out the stock regulator with a 2-stage harris and a swagelok low flow metering valve. Milwaukee needle vale is left alone because 1st, I wanted to minimize the changes/cost, 2nd it was a bit difficult to take off.
    [​IMG]
    Heemskn also swapped out the stock Milwaukee needle valve with a parker metering valve.
    here is his built.
    [​IMG]
    #4 darkoon, Oct 22, 2010
  5. abcemorse
    Sep 8, 2008
    83
    4:22 PM
    Cool, thanks for the replies, guys!! Helps a ton!
