Question: Holes in Carolina Cobamba - Mainly at the bottom
Discussion in 'Are you new to aquatic plants? Start here' started by Monilovesplants, Aug 17, 2013.
  1. Monilovesplants
    Monilovesplants Prolific Poster
    Nov 27, 2011
    77
    3:07 AM
    So I'm getting holes and wondering, I know I've upped my fertilizers but I'm thinking, if I'm getting holes is that mostly a potassium deficiency? If yes, would it be a good idea to increase that a bit and replant my plants and watch the new leaves. I know the old leaves are not fixable but I'm guessing I just have to watch and see if it gets worse. My plants are looking better but still getting some weak leaves on these.
    Monica
  2. Solcielo lawrencia
    Mar 20, 2013
    1,007
    44
    3:07 AM
    It's probably a K deficiency. The amount of K in KNO3 isn't enough. Are you adding K2SO4?
  3. Tug
    Tug Lifetime Charter Member
    Jan 5, 2009
    1,150
    3:07 AM
    It could also be a CO2 deficiency. Are you adding KH2PO4?
    FWIW, I add about 1ppm of K+ to my tank in addition to EI dosing.
    If you're dosing KNO3 and KH2PO4 you shouldn't need much K+.
    Did you ever find out what you are using to soften your water?
    What do you mean by weak leaves?
    Plant Deficiency Checklist + Diagram
    http://infographics.myaquacalc.com/wp-content/uploads/2010/11/plant-deficiency-labeled2.jpg
  4. Monilovesplants
    Nov 27, 2011
    77
    3:07 AM
    Under-dosing maybe?
    I do Potassium Sulfate 3/4 of a teaspoon 3X a week. I add 1 tsp of phosphate once a week.
    Would that be enough or am I seriously underdosing on both? I've got powdered versions of both so can add it dry. Right now the amount I'm dosing is dry.
    I also added 1 tsp of calcium and 3 tsp of magnesium (epson salts) when I do water changes due to the water system.
    Monica
