If you got it in a pot with rock wook keep some of the rock wool attached to the roots to use as plugs and plant it in the substrate. Without rock wool, if you have fine substrate you can try to plant them directly in the substrate.
The way I do is this: I wrap the short stems around small rocks with cotton thread, and lay down the rocks. In a couple of weeks the rocks disappear under the spread carpet,
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
