Question about lighting
mexicatz
Feb 10, 2015
85
I received the par data from finnex for my planted plus at 13 inches which came in at 62 par. I use a piece of window screen to cut the par by about 40% based on others testing. This puts my par at about 37 at the substrate.
Some of the plants that I have in the 37 par are starting to grow algae while plants in the shade show no deficiencies or algae. I was wondering if it would be better to add another screen to cut the par to about 23 or if increasing my excel dosage to 1.5-2x would solve the problem. 37 par seems pretty close to the safe range to avoid algae with low light so I'm not sure.
Phishless
1,103
972
Arnold, MD
How long is the photoperiod?
Cutting PAR in a low light tank will reduce algae.
Is raising the light an option?
Glut/excel is a decent algaecide too.
Ever considered adding CO2?
mexicatz
Feb 10, 2015
85
the photo period is 6-6 1/2 hours and right now i've added the second piece of window screen so I think the par is around 22.
I've looked at some led raisers that raise the light 3,4, or 6 inches but the par would be very close to what I can achieve with the window screen.
Do you think I should stay at the 22? or should I try 37 with 1.5-2x excel dosing
I've considered co2, but it probably wouldn't be a realistic option while I live with my parents.
barrreport.com
Nov 20, 2011
1,584
388
83
49
UK
barrreport.com
I've always used Hoppy's ( @VaughnH ) reference for par values and if we need co2 based on that par.. low, medium, high light.
Here is a quote from Hoppy.
I don't believe there is any consensus about the definition of low, medium and high light. But, here is my definiition, subject to, and almost certain to change:
  • Low light - 15-30 micromols of PAR - CO2 is not needed, but is helpful to the plants
  • Medium light - 35-50 micromols of PAR - CO2 may be needed to avoid too many nuisance algae problems
  • High light - more than 50 micromols of PAR - pressurized CO2 is essential to avoid major algae problems
Off topic but it would be great if he wrote a updated version of his great lighting article here on the Barr report ;) hint hint :D
Reactions: snarkingturtle
86
I suggest considering this set-up/method: http://www.aquaticplantcentral.com/forumapc/general-aquarium-plants-discussions/133058-diy-co2.html
No, I don't plan to update my lighting article in the near future. That was a lot of work, spread over a lot of weeks, and I don't collect lighting data for newer light fixtures now. I still think the basic facts in the article are correct, even if the charts of PAR for various types of lighting are obsolete.
I'm now pushing the idea of borrowing a PAR meter to get a relatively accurate reading of the actual PAR you have at the substrate, with your specific lighting and set-up. To make that easier I am loaning out a PAR meter at a reasonable cost - shipping and insurance only. See: https://barrreport.com/threads/apogee-par-meter-for-rent.14334/
