Question about CaCl2*2h2o
Discussion in 'Aquatic Plant Fertilization' started by nilocg, Apr 3, 2014.
  1. nilocg
    nilocg Prolific Poster
    Jul 29, 2010
    70
    2:10 PM
    Can someone help with with figuring out the PPM Calcium and dGH with the following:
    Adding 210grams CaCl2*2h2o into 500ml RO. Then dosing 1ml into 1 gallon.
    What will the resulting PPM of Calcium be? What about dGH?
    I used a fert calculator which came up with:
    Compound/PPM
    Ca/30.239
    Cl/53.5
    dGH/4.22
    Is this correct? It seems the dGH is about double what is should be? Any help would be appreciated.
  2. AaronT
    AaronT Member
    Jul 29, 2013
    195
    2:10 PM
  3. nilocg
    Jul 29, 2010
    70
    2:10 PM
  4. Knocker
    Knocker Lifetime Charter Member
    Feb 5, 2008
    2:10 PM
    Hi, its quiet easy:
    you can use ISO-6059 formula to convert concentration of Ca an Mg to GH. it will be:
    GH (mmol/l) = C (Ca)/40+ C (Mg)/24.3, where C(Ca) and C(Mg) are concentration of mentioned elements in mg/l (ppm)
    Then if you want to convert your received result to most common unit German general hardness (DH), you must multiply calculated result by 5,61.
    So here you go 30,24/40*5,61=4,24 GH (DH)
