Hi All
maybe this question has already been answered before...
I have TetraTex 1200 and a 1000 lph pump that feeds a CO2 reactor, currently separated in the tank. There is a pre-filter doing mechanical filteration & then this water is drawn into TT 1200 cannister & the pump.
Can/How should I connect the outputs of these 2 in parallel?I am less worried about the flow loss, than any back flow/pressure on the 2 pumps. The TT1200 has very less media inside & hence a good flow (havent measured it, but guess its around 800 lph at least). The pump draws the water from tank, and pushes it out of a CO2 reactor (Aquamedic type). Both have separate spray bars at the output. I would like to combine these spraybars into a single one.
Any ideas?
Many thanks,
Niru
Any ideas?
Many thanks,
Niru
