Purigen filtration question
Discussion in 'General Plant Topics' started by Lightt, Jun 30, 2016.
  1. Lightt
    Lightt Junior Poster
    May 27, 2016
    45
    4:01 PM
    Hello,
    What do you think about seachem purigen ;
    I v seen some hobbyists using it at planted tanks.
    And if someone uses it and there is no nitrate production because purigen controls ammonia, then what should we do; Increasing our nitrogen-kno3 dose; I used this product for a while at the past and i remember my nitrates were near zero. So , if we have a heavily planted tank and use this product, how we deal with nitrogen;
    Thank you in advance
  2. burr740
    burr740 Micros Spiller
    Staff Member Moderator
    Feb 16, 2015
    1,398
    1,300
    10:01 AM
    Ive been using it for maybe six months in a couple of tanks. From a visual standpoint cant tell much difference really.
  3. Lightt
    May 27, 2016
    45
    4:01 PM
    And what about nitrates which tend to zero;
  4. pablo12345678
    pablo12345678 Junior Poster
    Jun 16, 2016
    10
    4:01 PM
    I use for heavy tannin stain. Works very well. That's only difference I notice.
    I heard it reduce dissolve organics also but is not miracle cure.
  5. Lightt
    May 27, 2016
    45
    4:01 PM
    I am using it 2 days now because i have problem with nitrates, probably ammonia from substrate. Seems to work, i am counting for about 5 nitrates. But my question is, do the plants starve ; Shall i increase my kno3 dosages;
  6. rajkm
    rajkm Article Editor
    Sep 16, 2015
    677
    218
    4:01 PM
    Purigen only removes organics which if left turns to ammonia and then nitrates.
    It does not really absorb any ammonia directly. But it is know to absorb some trace elements.
    if you are dosing kno3, purigen wont take it out. But if you were counting on bacteria to provide nitrates then you might be short. I would recommend putting Purigen after bio filteration so you still get nitrates from nitrogen cycle and any organics that did not get converted gets absorbed by Purigen.
  7. Lightt
    May 27, 2016
    45
    4:01 PM
    I have purigen after bio media and before wool. So i have 1 box with my blue sponge , 2 boxes filled with bio media and last box has purigen and wool.
    I am using nitrogen seachem for now to add nitrates. But i am still counting for about 0 at the end of my photo period. If i remove it , i have problems probably from substrate with nitrates going over 20 in few days.
    So this is why i am afraid about starving plants and cyanobacteria issues.
    In conclusion, this ammonia control with purigen seems to help a lot controlling filamentous diatoms which are my main issue at this tank..
    4 ml nitrogen per day is like 3,3 no3. Should i double this dose to 8ml;
    Thank you
  8. kb27973
    kb27973 Guest
    10:01 AM
    Makes my water crystal clear. I just wish it was cheaper. Haven't tried to regen it.
  9. 1077
    1077 Guru Class Expert
    Aug 19, 2010
    189
    4:01 PM
    I would want to know what nitrogen level was on last day of week before water change day.
    If nitrogen levels were between 10 and 40 ppm in planted tank I would not worry bout it.
    If the nitrogen level was lower than 10 ppm by week's end,then I might add a bit more KNO3 to get to 10 to 20 ppm by week's end.
    KNO3 is inorganic so purigen should have little effect on it,only affect's organic matter .
    For what it's worth,uncalibrated API nitrogen test show's my low tech tank's at nearly 80 ppm by week's end so...I just put away the nitrogen test and feed fish well.
