purigen/charcoal to deal with diatoms
Discussion in 'Algae Control' started by IUnknown, Feb 7, 2016.
  1. IUnknown
    IUnknown Lifetime Members
    61
    10:56 AM
    I've setup a new tank and I've always had a diatom bloom when using new substrate, from the silicate. This time around I used purigen and charcoal and have not had any issues with diatoms. I was wondering if it could be because of the purigen/charcoal? I've read that you can skip cycling a tank because the plants do the job, so I was not worried about delaying cycling on the new setup.
  2. PhilipS
    PhilipS Lifetime Members
    May 10, 2014
    254
    23
    3:56 AM
    Answer is no.
    Now that you came this far, plant more or propagate/clone more. Let the plants and bacteria do the rest.
    Let the plants grow out before trimming.
    I'd rather dust the diatoms with ADA bacter 100 and then 2 days dark than using any chemical.
