Pump for co2 reactor
DemonUnleashed
Nov 30, 2013
Wisconsin
Hi. On my 50 gallon tank I have a Fluval 406 filter. I have been running a 20 inch long Rex Griggs style reactor and Hydor inline heater on that canister. The flow has gone down quite a bit. Would I be able to use a pump like a Sicce Syncra to move water through the reactor and heater? If so how many gph would be ideal? Thanks in advance for your help.
Reactions: quangnvi
rajkm
Article Editor
Article Editor
Sep 16, 2015
677
218
43
Hillsboro, OR
I run a dedicated loop for Rex Griggs in my garage tank. I would suggest to higher but add a ball valve to control.
Christophe
Subscriber
395
269
63
Albuquerque, NM, USA
I use a Sicce Syncra 1.0 to drive a 20" x 4" Grigg style reactor in my sump, for an 80 gallon system. you'll probably need the next size down to do an independent loop for your 50.
DemonUnleashed
Nov 30, 2013
Wisconsin
Would I still want to use a syncra .5 with the head pressure of 49 inches since the pump will be down in my stand? Also would the filter pipes feeding the reactor create more pressure?
