Pros And Cons Of Gfci
Discussion in 'General Plant Topics' started by Kathy328i, Feb 11, 2020.
  1. Kathy328i
    Kathy328i Lifetime Members
    Feb 3, 2011
    41
    3:53 AM
    It's been recommended that I NOT add a GFCI outlet for my 120 gallon tank setup because the GFCI occasionally trips and that would be disastrous if it happened while away on vacation. It was recommended that I arrange the electric cords as "drip" lines.
    Pros and Cons?
  2. Deanna
    Deanna New Member
    Aug 23, 2018
    29
    10:53 PM
    My tank sits on an open stand and has various electrical connections, underneath, running through a UPS. There was no avoiding it: occasionally, it was carelessly or uncontrollably doused with enough water to fry it (meaning a new one had to be purchased). I added an inline GFCI (not a wall outlet) and when it does happen, the GFCI steps in and saves it. Additionally, I like the idea of never worrying about an unpleasant surprise when I put my hands in the tank. However, equipment shorting occurrences are reported to be extremely rare. In three years, the GFCI triggered while I was away, once, but that was only a day. If I'm to be out for more than a day or two, and no one is home to attend a problem, I simply unplug it from the GFCI and bypass it.
Tags:
