Hello there!
After reading the threads here for some weeks now and applying the EI method for my tank I still have a lot of problems. I would really appreciate any help.
So I'm starting with a list with things I already changed and the general setup of my tank.
Volume: 550 litre / ~ 350 gallons
Lightning: 2x80 w t5 with reflectors, 12 hours a day
Filtration: "Hamburger Mattenfilter" with 2 "mammoth-pumps" which nets about 1600 l/hr
Co2 with drop checker: About 20 mg/l right now. Mixed in with a diffusor, directly under the "Mattenfilter"
Temperature: 28 °C
Substrate: Only Sand
Tap water analysis: http://www.amperverband.de/media/files/allgemein/kurzanalyse.pdf , please scroll down there
Water changes: About 40% Each week, 50/50 - RO Water and carbonfiltered tap water
Fertilization:
Due to my low lightning I started to fertilize as follows:
Day of water change:
4,9 g KNO3
1,2 g KH2PO4
13 g Epsom Salt
The day after:
Seachem Iron 8,5 ml
Trace 10 ml
Plants:
Mainly Echinodorus, which should be one of the easier plants to grow.
I measured Nitrate, Fe and Phosphate. Nitrate was between 20 and 30, Fe was nearly unmeasurable, although I'm already adding Seachem Iron, Phosphate was around 2.
Problems are the following:
1. Leaves are starting to turn yellow, beginning at the edges
2. Some are turning dark green
3. Some leaves are "twisted" and "wavy" - I hope this is the right adjective for it
4. The following algae are growing: Mainly Cladophora algae and GSA
Questions:
1. I already searched in other threads for this but didnt find an answer: My surface agitation is really high, does this affect the co2 negative? I already increased the Co2, now it's about 3-5 bubbles per second, so normally this should be enough. Any opinions on that?
2. Is there anything I can optimize right now? The only thing I'd like to keep is the light, but maybe it's too low to grow anything...
Hopefully my writ wasnt formulated too bad, since English isn't my mother tongue ;-)
I know it's a long post but I really don't know how to fix my problems.
Thanks in advance!
Greetings
Matt
Temperature: 28 °C
Fertilization:
4,9 g KNO3
1,2 g KH2PO4
13 g Epsom Salt
The day after:
Seachem Iron 8,5 ml
Trace 10 ml
Plants:
Questions:
Thanks in advance!
Greetings
Matt
