PO4 sources
Discussion in 'Estimative Index' started by chopsticks, Mar 17, 2011.
  1. chopsticks
    chopsticks Prolific Poster
    Jan 20, 2011
    70
    7:37 PM
    Hi all,
    I'm new here, (and new to aquatic gardens), I want to start IE dosing my tank, but I haven't found where to buy KH2PO4 in small batches where I live (Costa Rica), only wholesale 25kg bags.
    So, I was wondering if I can use orthophosphoric acid (H3PO4) as a source of PO4, because it is more readily available here.
    Cheers,
    Juan
  2. nipat
    nipat Guru Class Expert
    May 23, 2009
    665
    7:37 PM
  3. nipat
    May 23, 2009
    665
    7:37 PM
  4. Cyclesafe
    Cyclesafe Guru Class Expert
    Jan 19, 2011
    136
    7:37 PM
    5 mls of Fleet Enema (look in pharmacy) has the same amount of PO4 as 1 gram of KH2PO4.
  5. pat w
    pat w Member
    Nov 4, 2009
    462
    7:37 PM
    Dosing calculations for Fleet Enema are also included in ACP's Fertilator, and in my StockSol Spreadsheet.
    Pat
  6. chopsticks
    Jan 20, 2011
    70
    7:37 PM
    $7 133 ml bottle of Fleet Enema on my nearest pharmacy, the equivalent of 26.6 grams of KH2PO4.
    Thanks a lot to all!
    Juan
  7. barbarossa4122
    barbarossa4122 Guru Class Expert
    Dec 29, 2009
    975
    7:37 PM
    Can you find generic one? Same thing and cheaper.
  8. chopsticks
    Jan 20, 2011
    70
    7:37 PM
    Cool, I'll try to get the generic one,
