Well, just got an Aqua Medic 1000 CO2 reactor and a Quiet One 1200 (296 gph) water pump (of which I have sitting outside the tank). I've used 1/2" ID clear tubing and worm-drive clamps I got from the hardware store to hook everything up. I'm fine tuning the bubble rate and general operation of the C02 but my setup has about as few kinks as a strip club on a Saturday night
A couple questions:
1. How do you guys manuever the tubing without it kinking? When I have the intake line coming out of the tanking and heading down toward the pump on the ground it kinks. The return line from the reactor to the tank kinks. How do you work without this stuff kinking?
2. What attachments do you use for the end of each of the lines (intake and return) in the tank? Right now I a nylon mesh made from an old dress sock (don't worry - I washed it!) rubberbanded around the intake to keep things from getting sucked in, and nothing on the end of the return line. Because the tubing is so hard to get it to stay where you want it pointed (tends to want to spring back), it would be nice to get some advice on fittings people use at the end of the return line.
