Please Help Downoi Pogostemon helferi - Stunted growth
Discussion in 'General Plant Topics' started by thong123, Dec 27, 2015.
  1. thong123
    thong123 Junior Poster
    Jun 10, 2015
    47
    7:38 PM
    My Downoi been like that for about 1 month already.. Just the top
    of the plant has leafs and its rather small.
    Had a full carpet of Monte Carlo, but ended up yanking it out. Just replanted some of them from the picture below. Please advise on
    what wrong with my tank ..Could it be Ferts?Substrate too old ? but why does my monte carlo and other plants grow so well.
    Thank in advance
    Using Ray2 & Planted + for lights
    High Tech Co2 system
    Substrate ADA Amazonia- 2 years used
    Dont dose any fert..maybe 1 week once excel
  2. Solcielo lawrencia
    Mar 20, 2013
    1,007
    44
    7:38 PM
    Need to dose fertz. Excel is not a fertilizer.
  3. PhilipS
    PhilipS Lifetime Members
    May 10, 2014
    254
    23
    12:38 PM
    Actually Glutaradehyde is C5H8O2, that how it works as an alternative carbon source. More expensive than CO2, and causes swings in the balanced aquarium. Good to use while you do stabilize the aquarium to minimize BBA.
    Your LFS may have a bottle of plant ferts on sale or you need to get something online. I have Osmocote+ capsules if you do not want to fertilize daily or Ei method.
    Have a pic of the Downoi? Maybe under the higher lights the Downoi is staying smaller. I cannot answer this because mine got chewed by something.
    What is your CO2 level? You can estimate the CO2 with a pH-Kh Chart or
    AquariumInfo.org/co2calculator.html
  4. thong123
    Jun 10, 2015
    47
    7:38 PM
    noted Mr tyvm
    2 bubble per second from the counter. will use the chart thx again
    #4 thong123, Dec 28, 2015
  5. Tom Barr
    18,694
    728
    7:38 PM
    I'd not use Excel till a good month or two after the tank is done, downoi tends to do poorly in new ADA AS. More water changes will help. It will recover and do fine later.
  6. thong123
    Jun 10, 2015
    47
    7:38 PM
    sweet tyvm Mr
