Planted Frontosa Tank
fmueller
Aug 31, 2020
13
54
Auckland, New Zealand
I am new to the site and am planning to go the CO2 route. But figured I'd share an image of my non-CO2 planted Frontosa tank as a starter.
fmueller
Aug 31, 2020
13
54
Many thanks! The trick with Frontosa seemed to be using plants that are not rooted in substrate. Frontosa don't eat plants, but they dig! The tank uses only plants that can be attached to driftwood - Java Fern, Java Moss and Anubias species. The Cryptocoryne in the front left hand side disappeared slowly but surely. ;)
Unfortunately I don't enjoy the same success with those plants at my new place of living.
jbs47
99
32
73
Central Florida...St Cloud.
I am sure you will...I can't imagine moving from US to New Zealand. Same attention to detail will get you there with planted CO2 tanks. Your frontosa tank is very clean and I know how messy big cichlids can be. Do the same and problems should be minimal with your new endeavors. What are the water parameters in your part of New Z. BTW, love those humps.
tiger15
Aug 12, 2017
240
82
28
68
NJ
Very nice Frontosa planted tank. What type of Frontosa do you have?
I also keep one Zaire Frontosa in my large cichlid planted tank. I use a lot of epiphytes attached to larva rock, and a few rosette and stem plants secured in hydroponic pots to prevent digging. I don’t plant anything in the substrate which is barely 1/2 inch to cover the bottom. Why do you want CO2 since your epiphytes are already thriving and appear free of algae. I use CO2 so I can have a couple color stems.
You and I have demonstrated that with proper aquascaping, big cichlid can coexist with plants. I also don’t find high bio load cause algae, as my cichlid eat and poop a lot. But I’m diligent to clean filters often and do weekly 75% WC.
Reactions: Jason King
fmueller
Aug 31, 2020
13
54
Sorry for the late response. I finally manage to get some water tests done.
KH 90 ppm
GH 150 ppm
NO3- 0 ppm
pH 7.8
In the US my plants used to thrive under virtually identical conditions. Here in NZ not at all. That said, I have never reached good stocking levels in NZ. Stupid mbuna keep killing each other faster than I can ad them.
I wonder if I should just try adding fertilizer for the plants. CO2 for a 2000 liter setup is going to be pricey!
fmueller
Aug 31, 2020
13
54
That is one interesting setup you have! You don't see too many Frontosa in a community tank!
My Frontosa were good old fashioned Burundi. I started with 50 and kept selling them as they outgrew the tank until I had a nice, female heavy colony.
I was totally happy with the Frontosa tank. It wouldn't have occurred to me to ad CO2, but my current tank is a mess. Therse plants are over 2 years old. The Java fern isn't doing anything, the Anubias are covered with algae and Crypts bring tears to my eyes!
jbs47
99
32
73
KH 90 ppm
GH 150 ppm
NO3- 0 ppm
pH 7.8
If you want to grow a lot of the difficult plants,,ie some rotalas, downoi, buces, etc...you will need CO2 but I have had some luck with a good quality fertilized substrate like ADA with no CO2. You could try that. Best and most cost effective ferts are the dry ferts which can be ordered in US from aquariumfertilizer.com and hopefully can be shipped to NZ. KNO3 may be a problem to ship depending on NZ laws.
fmueller
Aug 31, 2020
13
54
Shipping anything to NZ costs an arm an a leg. But if I know what I need, I can get it. I am a research chemist. ;)
tiger15
Aug 12, 2017
240
82
28
68
NJ
Your water parameters are almost the same as mine so there is no reason you can’t grow plants. I notice in your Mbuna tank the plant mass is too small, which is an invitation for algae invasion. You need to have high plant mass to outcompete algae at the start. If you can’t get enough Java fern to fill up, get a big chunk of cheap Hornwort as temporary plant mass and dispose of it when the desirable plants are established.
I struggled with bba and other algae at start up too. I dosed Excel (glutaldheyde) following Seachem recommended dosage, and sprayed with peroxide on exposed plants and surfaces during WC when the tank is drained, and the algae was gradually gone. Having CO2 will make plants grow faster, healthier, and get rid of algae even faster.
Mbuna is not the same as Frontosa. Fronts are peaceful colony cichlid that work well with plantts. Mbuna are ultra territorial and plant eater. There is dominos effect in Mbuna aggressiveness. When the colony is reduced by killing, the smaller colony becomes more dangerous to the next weakest fish the gang will focus on. So the killing will continue till one fish stands. Growing plants with large cichlid is possible, but one needs to be selective on what type of plants and fish can be housed together, and Mbuna is not one that fits IME.
fmueller
Aug 31, 2020
13
54
Thanks! I appreciate your advice.
Yes, with Mbuna you are very limited in your choice of plants. I picked the ones I have, because I previously had good success with them in a Tropheus tank.
jbs47
99
32
73
Good advise from Tiger15...Look thru the fert site for information and then go about finding KNO3, Fe G, PO4 source, K2SO4, etc. As a chemist, this should be no problem if all are available in NZ. Rotala butterfly on this site will provide dosing info for your tank size...My water parameters are very hard so I use an RODI filter to bring down the TDS. Your water should grow most plants, IMHO.
Reactions: fmueller
fmueller
Aug 31, 2020
13
54
I am busy reading up on EI. ;-)
Macronutrients should be no problem to procure. I need to do some research on what to use for trace. The common brands sold in the US are not available here, and mixing those myself seems a bit of a hassle - especially if I could find something ready made with a bit of research. I might hit some plant stores tomorrow.
tiger15
Aug 12, 2017
240
82
28
68
NJ
Can you get Seachem Flourish comprehensive in NZ? I dose Flourish after weekly WC and dry DTPA iron every other day. DTPA Fe lasts longer in my alkaline water which ranch from 7.8 to 7.0 pre and post CO2 period.
I love your Tropheus planted tank, another demonstration that cichlid can be kept with plants. I have never had Tropheus for fear they are as pugnacious as Mbuna. You had some nicely scaped holly rock, Annubias, Java fern and bolbitis. I have lot of Anubias of different variety attached to lace rock in my 75g. I have holly rock too but I found epiphytes have hard time attach to. It appears that you have alkaline substrate too, and what’s your pH? I use dolomite gravel which is less soluble and thereby less alkaline than crushed coral or African Mix. With alkaline rock and substrate, there is never a deficiency of Ca/Mg and the need to dose gH.
