Plant Spacing Advice Please
Discussion in 'General Plant Topics' started by bardus71, Jul 10, 2011.
  1. bardus71
    bardus71 Junior Poster
    May 11, 2011
    10
    7:56 PM
    Hi to the international aquarium enthusiasts & also to fellow AL members from Australia.
    I am about to plant out my first scape with stems & groundcovers in a 4' low tech tank.
    It will have gravel capped soil/potting mix, no ferts or CO2, and ~2WPG lighting on for 14hrs/day.
    I have no references for how far apart to space my plants & groundcovers so they dont overcrowd once they grow in. Any advice or pointers to where I can get more info is welcome.
    Groundcovers: Marsilea hirsuita, Stauryone tropica, Lilaeopsis spp, Dwarf grasshair
    Stems: Ludwigia repens & scarlet ludwigia, Hygro polysperma & sunset hygro, lace fern, millifoil, ambulia, blood stargrass, Pogo stellatus, Val spp
    Also: Crypt wendtii
    Thanks,
    Bardus.
  2. dutchy
    dutchy Plant Guru Team
    Jul 6, 2009
    7:56 PM
    Hi and welcome to the Barrreport,
    As a general rule I use in the density of planting stems is that the leaves of one stem are allowed to barely touch the next plant. But then again, I like dense plantgroups. Also density is dependent of the amount of light you use. More light makes more density possible. If lower leaves fall off to soon, and it's not a nutrient deficiency, you might be overcrowding.
    Ground cover can be planted in small groups or single plants with 1 to 2 inch spacing. The plant will do the rest.
    You might find this resource useful:
    http://www.aquaticplantcentral.com/forumapc/plantfinder/
    #2 dutchy, Jul 11, 2011
  3. Crispino Ramos
    Crispino Ramos Guru Class Expert
    Apr 23, 2010
    278
    7:56 PM
    Most Rotala sp like R rotundifolia can be planted in a bunch of say five stems or more. Hygrophila sp is preferably planted leaf tip to leaf tip apart.
  4. bardus71
    May 11, 2011
    10
    7:56 PM
    Thats awesome advice so far, thank you. Does the leaf tip rule applt to things like lace fern & ambulia/milifoil type plants as well?
