Plant Question
ilaizm
Feb 23, 2009
I have two questions.
1. Is the plant in the attached photo an Anubias?
2. Can you see the leaf which has three small holes on it. Should I cut the leaf off immediately or keep it as is?
thanks
89
Do you have this anubias growing underwater? A reason to remove the leaf with the holes would be to prevent it from attracting algae, if it is growing underwater.
ilaizm
Feb 23, 2009
Thanks for your confirmation.
I considered whether I should remove it as I read that when a leaf starts turning yellow you should cut it off to give strength to the other leaves coming up.
Yes its growing underwater.
