Just a quick note do I use Pipe Dope or Tape around my regulators threads like on CGA's , Gauges, witch would be best to use?
Matt F.;74116 said:I use teflon tape on all my connections for a more permanent fix. If bubble counter fluid or mineral oil come into contact with non-hardening thread sealer, it can cause leaks. Plus for higher pressure situations like CGA connections, teflon is a sure bet.
Biollante;74152 said:Hi Matt,
Sure easy for you to say, you know what you are doing...
Smarty-pants.
Actually, good point on the Teflon tape!
