Hi all,
I have a 120 gallon tank that I just planted about 1 week ago (fairly heavily). I have some questions about CO2 injection and pH trends over time, but first some facts about my tank:
For several days after I got the plants in, I had heavy pearling because I kept the CO2 cranked up 24x7 (no livestock to worry about) and I had all 4 lights on. My drop checker was indicating a mellow-yellow type color. However, I developed a bit of a case of Rhizoclonium so I decided to reduce lighting to two bulbs until I found my optimum CO2 since my research suggests that Rhizo is from too much light and too little CO2. Now, I'm running CO2 during the day with the lights (on 2 hours before lights and off 1 hour before lights go out). I have 5 Ottos and a couple of Bulldog Plecos in the tank, so I'm hoping they can help me find the optimum, maximum CO2 for the plants before causing stress on the fish. Since reducing the lighting to 2 bulbs and moving to CO2 off at night, I'm not noticing near as much pearling.
Here's a chart of my pH over the last few days:
The blue line is my pH and the red line is the on/off state of my lights. You will see slight inflections in the pH curves while the CO2 is on as I'm slowly increasing my bubble rate each day (I didn't adjust during the last CO2 on period). My question is in relationship to the pH and how long it takes to stabilize in the CO2 ON and OFF cycles. With CO2 on during lights ON, I'm not seeing the pH stabilize until 4.5-5 hours until after lights have been on. During the period when the lights are on, I do observe that my drop checker is a light green at the start of the period and a mellow-yellow color at the end of the period. With CO2 off during the night, pH doesn't stabilize at all really. It increases throughout the period until CO2 turns back on the next day. It does show a slow-down as if it is reaching an asymptotic limit, but never gets there.
Note, I'm not using pH to control CO2 at all. I tried that first and realized that was a bad plan since my KH changes before/after the weekly water change and would affect the pH vs CO2 relationship. I've noticed about 7-8 dKH after a water change and 10-11 dkH just before a weekly water change. I'm just using the pH for observational purposes.
My questions:
1) How much lag exists in measuring pH with a probe vs how much CO2 is actually dissolved in the water column? I'm assuming it is very low lag since I see immediate pH changes when CO2 turns on and off.
2) If the lag is low, does this mean my diffusion method (CO2 into the canister) isn't up to snuff since I'm not getting stability in the pH until 4.5-5 hours after the lights have been on (6.5-7 hours after CO2 on)?
3) Also if the lag is low, does this mean that the slow stabilization of pH at night means that my outgassing of CO2 from the water at night is slow? I've got significant surface agitation from the return of the canister filter plumbed through the returns drilled through tank. The surface ripples pretty well across the entire water surface.
I want to convince my self to not worry so much about what the pH is doing unless it really is telling me about a deficiency in my setup.
Thanks,
Clayton
- Lighting: 4x54W T5HO (2xAquaMedic Reef White 10k and 2xAquaMedic Plant Grow 6500K) - currently only running 2 bulbs until max CO2 limit is found (8 hour photoperiod)
- Filtration: 1 Fluval FX5 plumbed to the built-in dual overflows of my aquarium
- CO2: 20lb pressurized CO2 with solenoid, currently turning on CO2 2 hours before lights and turning off 1 hour before lights out, CO2 is injected into the input flow of the canister filter
- Substrate: Eco-complete, ~2-3 inches in front and about 4-5 inches in back with Osmocote Plus Rootabs inserted
- Fertilizer: Follow EI schedule with KNO4 (1.5 tsp), K2SO4 (0.5 tsp), and KH2PO4 (0.5 tsp) on Sun,Tue,Thu, Plantex CSM+B (0.5 tsp) on Sat, Mon, Wed, and 50% water change on Sat.
My questions:
Thanks,
Clayton
