  1. Dismiss Notice
PH drop and CO2 calculation
Discussion in 'CO2 Enrichment' started by camilocastroalvarado, Sep 6, 2014.
  1. camilocastroalvarado
    Aug 18, 2010
    122
    12:18 PM
    Hi everyone,
    I need your help on this. I've been battling with BGA on my 70 Galon tank for the last 4 months and plants are not growing as expected (I'm dosing almost 2 TBS of KNO3, increased current..nothing seem to help); finally I got an American Marine Pinpoint PH meter to check the tank's CO2. I took the PH readings and I hope you can help me to determine where I'm standing.
    Before CO2 comes on, ph is about 6.3, also I took water from the aquarium in a cup, agitated it and after a couple of minutes PH rises to 6.6. After an hour of CO2 injection, ph drops to 5.4 and then remains stable between 5.20-5.25 after an hour and a half. So let's say I'm having a 1.4 PH drop after 1.5 hours. Because KH is unmeasurable in my case, (less than 1°dKH), how can I know if levels are correct?
    I'm using a DIY wet dry filter and there's no splash in the overflow. CO2 is injected via DIY NW and 4x20" filter housing as reactor. CO2 enriched water is taken by the main pump.
    Thanks for your help.
  2. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:18 PM
    Do you have enough light? P? K? Micros?
  3. camilocastroalvarado
    Aug 18, 2010
    122
    12:18 PM
    Light is arround 90umol in the bottom. I dose the full EI (but increased KNO3 battling BGA)...KH2PO4, GH Booster and Fe/micros from CSM+B, Fe Gluconate and EDTA. I even changed my KNO3 supplier 2 times, didn't help.
  4. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:18 PM
    Ca and Mg?
    kH?
    Actually, what are the ppm of everything?
  5. camilocastroalvarado
    Aug 18, 2010
    122
    12:18 PM
    I rise GH a couple of degrees after a water change via Barr's GH Booster. KH is less than 0.5 degrees according to Sera and Tetra KH test kits, that's why I'm having problems measuring CO2.
    I'm dosing 2 TBS of KNO3, 1/4TSP KH2PO4 and I aim to 0.4ppm of Fe each dose. Nothing special I think, except for the KNO3.
    - - - Updated - - -
  6. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:18 PM
    So you are dosing:
    NO3>72ppm
    K>47ppm
    PO4=3.7ppm
    My guess is you are dosing too much Fe, not enough micros. I'd stop adding Fe except as CSM+B.
    A picture of your plants would help.
  7. camilocastroalvarado
    Aug 18, 2010
    122
    12:18 PM
    Thanks Solcielo, 0.4 of Fe calculated from CSM+B.
    Here are some photos.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    I recently cleaned everything, but it takes about 2 days to have everything covered with BGA. I tried the BO method, EM dosing...
    - - - Updated - - -
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    #7 camilocastroalvarado, Sep 6, 2014
  8. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:18 PM
    It appears you have a micronutrient deficiency causing veinal chlorosis, the yellowing of the veins. Add more CSM+B, don't add Fe in other forms.
    You also don't have very much plant mass so full EI isn't necessary.
    I'd also reduce lighting because 90 at the substrate is very high.
  9. camilocastroalvarado
    Aug 18, 2010
    122
    12:18 PM
    Thanks Solcielo,
    There was more plant mass in there, but I took a couple of species out thinking about CO2 competition. I'll increase CSM+B dosing and see if it helps.
    What about CO2?
    What's your opinion on BGA?
    - - - Updated - - -
    Thanks Solcielo,
    What about CO2?
  10. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:18 PM
    It's still not high biomass; even with all the plants filled in, it's on the low side.
    BGA: one of the easiest to get rid of. Correlation: poor plant growth = low dissolved O2 = BGA. It's obviously not an nitrate issue. Someone mentioned aerating the tank and that got rid of BGA.
    Also, how much ammonia is in the tank?
    #10 Solcielo lawrencia, Sep 8, 2014
  11. camilocastroalvarado
    Aug 18, 2010
    122
    12:18 PM
    Hi, Thanks for your help Solcielo
    I redid my micros mixture and started adding it yesterday as follows.
    3TSP of CSM+B
    1TSP of Iron Chelate bought from greenleafaquariums.com
    Since I couldn't get Fe Gluconate and I have Fluorish Iron locally, I added 30ml of it to get the same concentration Tom suggests in his mixture (arround 304ppm).
    20ml of excell
    Everything disolved in 1L of water.
    I'm adding 30ml daily.
    I was adding almost 140ml of CO2/min. I reduced it to 60ml/min, seems that efficiency was greatly affected as volume of CO2 increased.
    I did the sera KH test to get readings of 0.25dKH, and the aquarium KH was somewhere between 0.75 and 1 dKH. I used Alkaline Buffer to rise it to 1.5dKH. The aquarium PH is 5.54 now after 3 hours of CO2 injection. Agitated water for 2 minutes and the reading was 7.1.
    I'm still having a 1.46 PH drop even with the reduced volume of CO2, but according to the KH/PH cart with a KH of 1.5 and a PH of 5.54 I have 115ppm of CO2 (nuts), Should I assume that the only Carbonate Hardness is the increase of KH that I did with the Alkaline Buffer?
    Regards
    - - - Updated - - -
    3TSP of CSM+B
    20ml of excell
    Regards
  12. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:18 PM
    Is the tank fully cycled? If there is a lot of ammonia, it can be toxic to plants and stunt their growth. Hopefully you did a lot of WCs in the beginning to remove them, or use a fully cycled filter.
    I don't know what's in alkaline buffer so I can't help you there but there is probably carbonates.
  13. camilocastroalvarado
    Aug 18, 2010
    122
    12:18 PM
    The tank has been running for about a year, I'm doing 60% WC every fourth day.
    This is what rota.la calculator shows about my micros dose per day
    B 0.01
    Cu 0.00
    Fe 0.08 + 0.07ppm of Fe from FE gluconate + 0.03ppm of FE from Iron Chelate
    Mg 0.02
    Mn 0.02
    Mo 0.00
    Zn 0.00
    dGH 0.00
    Seems a bit low according to this quote from Tom Barr:
    B 0.17
    Cu 0.01
    Fe 0.94
    Mg 0.20
    Mn 0.27
    This is about what I dose for my tanks per dose, 3-4x a week.
    ~1ppm is a typical dose for Fe.
    Not 0.1ppm.
    am I missing something?
    - - - Updated - - -
    B 0.01
    Cu 0.00
    Mg 0.02
    Mn 0.02
    Mo 0.00
    Zn 0.00
    dGH 0.00
    B 0.17
    Cu 0.01
    Fe 0.94
    Mg 0.20
    Mn 0.27
    Not 0.1ppm.
  14. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:18 PM
    You might be adding too much iron. Excess iron can be toxic or prevent the uptake of other nutrients.
    Edit:
    also, those ppm's are without the addition of extra Fe.
    #14 Solcielo lawrencia, Sep 9, 2014
  15. camilocastroalvarado
    Aug 18, 2010
    122
    12:18 PM
    Solcielo, I wrote to Tom about the information I've found and posted before. He agreed with what you've been saying.
    I reduced the Micros dosing to 10ml/day
    The preparation is as follows: 3TSP of CSM+b + 1TSP Fe gluconate + 1TSP Iron Chelate DPTA in 1L of water.
    According to rota.la calculator, I'm adding:
    B 0.003
    Cu 0.000
    Fe 0.028 + 0.014 from DTPA + 0.01 from Fe Gluconate TOTAL FE: 0.052ppm
    Mg 0.006
    Mn 0.008
    Mo 0.000
    Zn 0.002
    dGH 0.001
    What do you think?
    - - - Updated - - -
    B 0.003
    Cu 0.000
    Mg 0.006
    Mn 0.008
    Mo 0.000
    Zn 0.002
    dGH 0.001
    What do you think?
  16. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:18 PM
    I wouldn't add the extra Fe unless it's apparent that it's needed from observable deficiencies. CSM+B has a lot of Fe in it already. Using extra may not help and it may be causing the issues you've been experiencing. I'm repeating myself but excess Fe can cause deficiencies in other nutrients.
  17. camilocastroalvarado
    Aug 18, 2010
    122
    12:18 PM
    I can dose the CSM+B dry alone and see if it helps, but, ¿how much is a recomended dose?
    I'm a bit confused, 0.1ppm of Fe is what I've read, Tom said in other forums that 1ppm, but my calculations doesn't match.
    - - - Updated - - -
  18. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:18 PM
    Since you're using the nutrient calculator, just go by that.
    You also need to consider only your tank, not someone else's, when making decisions about dosing. Different tanks have different requirements. You have way too much light for what you're growing, imo.
  19. camilocastroalvarado
    Aug 18, 2010
    122
    12:18 PM
    Hi everyone.
    After a week, some things improved.
    Good news: BGA is almost gone. I can't tell if any specific change made it, but I'm sure that it has to do with plant's health. Ussually after cleaning, it took about a day to BGA to re-grow everywhere; now, there are little patches in the glass which I can assume to be normal.
    Bad news: Even with the plants growing a little better, there's something confusing about my CO2 levels:
    Here are some readings after 5 hours of CO2:
    Aquarium water PH: 5.23
    Agitated aquarium water PH after 5 minutes: 7.03
    KH from Sera KH test: 9-10 drops in 60ml (0.083dKH accuracy)
    KH from Tetra KH test kit: 8-9 drops in 60ml (0.083dKH accuracy)
    KH is about 0.74 degrees.
    Fish are stressed, but I think that if I had 130ppm of CO2 there wouldn't be any, and I would have more money from selling plants :D
    Questions:
    ¿Can such a low KH cause problems on PH readings? (I'm using an American Marine Pinpoint PH meter)
    ¿Is it wise to increase KH to take better/more accurate CO2 readings?
    ¿Can that be affecting plant's growth?
    - - - Updated - - -
    Hi everyone.
    Questions:
  20. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:18 PM
