PH Controller for CO2 system-Advice Needed
Discussion in 'CO2 Enrichment' started by RONY11, Feb 16, 2012.
  1. RONY11
    RONY11 Junior Poster
    Dec 20, 2011
    10
    4:23 PM
    I have a 60 litres net aquarium with rare plants n mosses.
    I use seachem fertilizers as per seachem chart have 1 watt/litre.
    Meanwhile I'm using CO2 DIY Yeast but as I can see its not sufficient.
    I have trouble growing glosso due to lack of CO2.
    I am planning to buy a used Eheim co2 system this weekend and need help/advice in deciding which PH controller should I buy.
    Attached pls find link to my planted aquarium.
    https://picasaweb.google.com/113229240846035240743/February10201202?authuser=0&authkey=Gv1sRgCJuk6-jp9PrRoQE&feat=directlink
    I am thinking of buying one out of these two PH Controllers t be attached to the Eheim CO2 system
    http://www.ebay.com/itm/WEIPRO-PH-20...11550763432814
    OR
    http://rover.ebay.com/rover/1/711-53200-19255-0/1?icep_ff3=2&toolid=10001&campid=5338187531&icep_item=250677554002
    If any hobbyist has used either of these PH Controllers pls mention the pro's con's of these PH Controllers.
    Thnx in advance
    #1 RONY11, Feb 16, 2012
  2. Squidly
    Squidly Lifetime Members
    Mar 30, 2009
    81
    4:23 PM
    If it helps, I recently purchased a Reef Fanatic controller for $129.00 on EBay and really like it. See: http://rover.ebay.com/rover/1/711-53200-19255-0/1?icep_ff3=2&toolid=10001&campid=5338187531&icep_item=350529936173
    Very nice calibration (set with a button - no screwdriver needed) and has a bright LED display. Seems very stable so far. If you intend to mount the unit on a wall as I did, the only drawback is the rear mounting cover which doesn't stay on very well (you can add tape to fix this)
