pearling stays underneath surface...
Martin
149
46
Sebbersund, Denmark
hi
i have pearling...which is nice...
now my pretty pearls tend to hang around right underneath the surface... as if something is keeping them from bursting..
is this normal? or is it some form of proteinlayer or what?
I dont really see any film.....
Symbiot
matthewburk
Oct 12, 2005
26
Re: pearling stays underneath surface...
I don't know if this is normal, but it is very bad. That layer is keeping oxygen out of your water. I learned this the hard way.
I have a high fish load and they were doing fine for months and then I started gettting more of a film on the surface than normal and they were all up gasping within 6 hours of the lights going off. I had to put in some powerheads just to keep the surface agitated enough to make sure this did not happen, becuase the oxygen deprivation caused a nitrite spike as well :( Now my surface is very turbulent and I could not even guess the bps on my co2, but probably over 40(its really a stream now, not really individual bubbles), and that puts me around 60ppm co2.
If you every find a way to solve this I would be interested in what you did.
reiverix
270
Wouldn't a surface skimmer help?
Jay
19
Gentle surface agitation and some flow work for me. I also keep two basic issue female black mollies who are constantly skimming the film off of the surface of my 75 gallon.
800
I make sure to have some surface movement always, gentle to quite fast, but not waves etc.
Cornhusker
192
tom,what causes this problem in the first place? i have a tank that does it all the time.it has a powerhead just below surface to get motion,but does not seem to help.the only tanks i get it in ,and that's seldom,are the ones with press. co2.the tank with the problem has onyx sand with leonordite below.regards,cornhusker :) :)
magicmagni
May 15, 2005
55
SF Bay Area
Some surface movement, good circulation and if I may something that is a little taboo in the planted tank niche..chemical filtration. No not activated carbon, but something that seachem makes called Purigen. It removes organics from the water that can cause that surface sludge. It does not impact traces or remove nitrates/ phosphates that we add to our tanks. By removing these organics from the water it helps your tank reach O2 saturation easier.
wapfish
Sep 25, 2005
34
A simple technique to get rid of surface scum and help the fish out at the same time is to run a bubbler for a few hours during the night, say just before lights on. This does not significantly impact the pH, at least in my 29g where I run CO2 24/7. pH stays right around 6.8 (KH = 7-8).
2 hours of bubbling totally removes the scum for most of the day, but it does start to return late in the afternoon.
Not sure if longer aeration would work even better, but when I originally ran the bubbler for 3 hours, it did seem like the scum stayed away longer. Have to go back and check this out specifically. Sort of an interesting thing in itself.
Spar
Jun 5, 2005
123
45
Dallas, TX
i went out today and bought a AquaClear 10 powerhead. on full-blast gives just enough movement to give a slight surface agitation. $20 at petsmart. seems to be doing the trick for my tank.
thanks for this post by the way! i didn't even realize that my tank was the same way until i read this and then took a hard look at my tank :) tall tank so I don't look "up" too often.
Martin
149
46
Sebbersund, Denmark
I disconnected my sandfilter, and that seemed to help. apparently the sandfilter had become too dirty to allow proper flow.
Anyway, this seems to have helped alot, and the surface seems more or less clean now.
I have another problem, but i will start a new thread on that... =)
800
Sand filters are touchy. They need cleaned often and cannot be stopped for too long.
Generally the protein layers form well when you have stagnet water, but mainly from a lull in plant growth, high organic build up, recent large changes to the tank etc, dying algae even,
A good water change and re set typically addresses it.
A good indicator I found was the organic content, but also the O2 levels.
So surface current increases should help some, along with and water change etc.
I think it's more fats than protein.
If you have low CO2, you'll see better growth withg the layer, if you have high CO2., the layer can over do the CO2.
It forms a barrier to gas exchange. Ideally, the gas exchange should be stable, the layer changes that.
