All,
I thought I would share some disappointing results with PC Lighting. The Power Compact (PC) lamps that I own which have a single bulb do not spread the light out evenly, especially on one side of the lamp. I believe this is due to the location of the plug, it blocks light distribution on one side of the lamp. These are Coralife lamps.
Please see the photo below, the red square is the plug. The blue square is the area that does not get much light. You can actually see that the reflector there does not reflect much when the bulb is on.
I have 2 tanks using these kinds of bulbs. The plants under this part of the lamp are dying in one tank, and are growing strongly in the other direction in the other tank. I have a fixture they raises them about 6 inches above the water, but this does not seem to be enough.
Cheers,
John
Cheers,
John
