Hi all,
I want to do a major scape change and replace/remove some of my substrate.
My 180 has an average substrate depth of 3-4" and it is at least 4 years old.
It is mostly red flourite (about 80%) of it, with some old normal gravel and black flourite mixed in. Most of the red flourite is now on top and all of the plantings are based in the red flourite. I have moved several times in the last several years, so it has been removed/rinsed/reused but not replaced.
I want to REDUCE my depth by about 1-1.5" in most places. I feel that I have too much depth and is much more than I need.
I would get a little more water volume as well. Plus, I want to add more contours to the top, as over the years it has been pretty flattened. I will have more depth where the plants are, esp for those with long root structures, but many areas will be much lower in appearance.
I also want to lay down a TOP LAYER of a NEW substrate to give it a nice fresh look. This new layer will be either:
1. Black Onxy sand
2. Black flourite
3. Plain black gravel
If I choose options 1 or 2, I would remove more of the existing substrate and replace it until my desired depth. This would be done PRIOR to replanting.
If I choose option 3, it will be a very thin layer, just enough to cover the top. This layer would be placed AFTER replanting, as it is very thin and I can easily do by hand around my new aquascaping.
My concern is basically losing bacterial filtration with the loss of the existing substrate and the effect on it's overall health and it's inhabitants.
I do not know how much of the beneficial bacteria exist in the substrate as opposed to the rest of the tank/filters/etc, but due to it's size in AREA (72X24), I suspect it is substantial.
Will this in effect cause a new tank cycle or even a partial spike?
If so, I can prepare with Zeolite and many large WC, but want to know what to expect. I know Tom replaced the substrate in one of his large tanks recently, and will revisit that thread, but didn't see exactly what I wanted to know.
My plan is as follows:
1. Remove 50% of water so easier to work with but fish have more room.
2. Carefully remove substrate desired.
3. 25% WC of remaining water.
4. Carefully add new substrate and shape.
5. 25% WC of remaining water.
6. Replant/aqauscape as desired. 50% of water in tank is no problem to work in and fish will be less stressed.
7. 25% WC of remaining water.
8. Fill tank as normal and run all filters.
9. Allow tank to settle/clear.
Basically then I would do about >50% daily WC until I felt safe, about 5-7 days and monitor/test.
1. Should I dose EI and c02 as normal during this 'recycle' time?
2. Are my expectations/plan reasonable? Or am I missing something?
Any advice or thoughts are always appreciated.
Or I guess I wouldn't have posted would I?
1. Black Onxy sand
2. Black flourite
