Parrot's Feather and Glosso
C
csmith
I picked up some Glosso today to replace my dwarf sag, which was getting a little boring as I've had it for quite some time and some myriophyllum aquaticum to fill in empty spots between other stems in my 20 gallon. Any tips/hints/warnings I need with either of these species? As I understand it glosso is relatively undemanding but I don't know much about the parrot's feather.
Run do not walk away from milfoil :)
Just kidding!
It is pretty undemanding and attractive, although some varieties are considered a pest...
http://www.invasivespeciesinfo.gov/aquatics/watermilfoil.shtml
Ensure you fluff it regularly and ensure a nice gentle flow to help keep it clear of debris....
I have kept and liked it but is hard to find in FL!
They grow quickly and will also grow nicely as floating plants but will quickly get very large..
They may quickly overwhelm a 20gal if not pruned regularly.
Good luck!
C
csmith
Run?! Biollante told me to run from planted tanks before I got addicted and you see how that advice went over with me. :p I was just reading about this stuff being banned in FL, MA, AL, CT and WA. By get large quickly do you mean up or out? These stems are thick! I plan on using them as a backdrop on one side of my tank and it sounds like this will perform as I need.
Thanks Gerry, once I get this stuff going I'll find a way to smuggle some down there for you. ;)
Don't even joke about that....
I was only kidding about availability and would not want it anyway with it being invasive....
Up and out is the way it will go. Big all over....
C
csmith
Of course, I'm sure you can obtain it fairly easily or it wouldn't be listed the way it is. Just some misplaced humor. Like I said, though, thanks for the answers as always.
