Hey all,
Some questions to anyone using this model or something similar like an Iwaki 100? Runs at 1950 GPH with a max head of 45'.
1. Is anyone experiencing higher water temp due to it's use?
2. If yes to #1, what have you done about it if anything?
I use mine on a 180 powering two NC canisters (533 mech and 547 bio) and a venturi bypass loop (model 584). It APPEARS I am using the full flow and no restrictions exist as my PSI guages read about 19 PSI which is about the max.
My water temp has increased at least 3-5 degrees F since I started using it and was just wondering if others have experienced the same issue with the same or equivalent size pump.
BTW does a fantastic job just runs hot........
Thanks in advance.
Thanks in advance.
