Oyster Grit for Ca and Mg Buffering.
Discussion in 'General Plant Topics' started by jarrod0987, Oct 30, 2015.
  1. jarrod0987
    jarrod0987 Subscriber
    Sep 7, 2015
    39
    12:17 AM
    In the past I had used RODI water and soaked some well rinsed Oyster grit in it for a few days to see how much GH and KH it provided. Some of us use crushed coral or Oyster Grit to buffer GH and KH. The results I got were 7 dkh for GH (125 ppm). I got 5.5 dkh for KH or Carbonate Hardness (98.2 ppm).
    Later, I decided to buy a more expensive LaMotte test kit to find out how much Ca and Mg. After 5 days of soaking some well rinsed oyster grit in RODI the results were GH (LaMotte calls it Total Hardness) 37 ppm and Calcium was 24 ppm. This would make Magnesium 13 ppm.
  2. Christophe
    Christophe Subscriber
    Oct 3, 2013
    395
    269
    12:17 AM
    Interesting result... How much oyster grit in how much water?
    #2 Christophe, Oct 30, 2015
  3. jarrod0987
    Sep 7, 2015
    39
    12:17 AM
    Small hand full in a jar of water. In past experiments I tried to determine of you can set the level by changing the amount of CC to water ratio. You eventually buffer up to the same level. It just takes longer with less CC or oyster grit. I want a stable system so I put enough that it buffers faster but there is still aa time delay. 2 weeks seems to be the fastest I can get it to stabilize no matter how much I add..
