Oursaunougat 240L tank (from 1 year old to future)
Oursaunougat
Nov 11, 2017
107
33
france
Would like an advice for this plant, may i let It grow and make new lateral stem to make It take the place i let for her, or should i trim and if trim how
Oursaunougat
Nov 11, 2017
107
33
france
GSA begin on all slow growing leaves, so i up the Po4, do am i right ? how many grammes of dry po4 would you put in one week in 240 L tank ? (to see if i am ok or not)
Allwissend
Super Moderator
Moderator
649
314
63
www.intuitiveaqua.net
You can cut it like any stem plant and replant the top. It branches easily, sometimes even with the top growing tip intact. Still I have seen others cut very low near the soild. In time this i will produce a big bush having a common root point. It takes a little bit longer to propagate in this fashion but makes for a nice result.
What compound do you use for PO? KH2PO4? If so, in a 240 litres aquarium at least 1g KH2PO4 per week. 1g is about 2mg/L PO4.
Regards
Mihai
Oursaunougat
Nov 11, 2017
107
33
france
Thanks for the two answers,
For po4 yes that is kh2po4
And i was already about 1gr by week
So i have tried this week about 3gr
I see also some leave twisting , is that mean too much of something or not enough ? And what ?
Greggz
448
578
93
I've gotta tell you something.
I know that the goldfish is going to be in every picture of your tank.
But every single time I see a new shot of your tank, it's surprising, like the first time you posted.
Just have never seen a fish like that in a tank like yours.
But it works for you, brings a unique element into the tank, that is for sure.
Reactions: Fissh
Oursaunougat
Nov 11, 2017
107
33
france
Thanks for your impression ,
The last one i keep and you can see on last picture is more than 20 cm long now , that is not always easy but by feeding him 2 Times by day that make him cool and he let the plant safe (or quite) the only perpetual problèm is that he vaccum ground often all day long and modify "terraforming" , so 2 Times by month i push , plan , and move back Gravel to make the thick i want in the tank .
And you are right i have never found advice on the web for keeping goldfish in planted tank cause surely noone do that
Reactions: Greggz and Mike k
