Osmocote Plus
C
csmith
Will adding maybe an inch or two of osmocote plus to an established tank cause problems for the inhabitants..like an ammonia spike?
DaBub
Oct 18, 2009
102
I would not use inches
Adding the stuff can be tricky, it won't cause problems though.
I go with 5 grams per sq ft, you can make it richer, but not more than cobverage of the bottom, not building up 2 grains deep etc.
excuzzzeme
Aug 3, 2009
Osmocote Plus should never be used in a tank containing Inverts as the amount of Cu is .05% which is a toxic level for some fish and most inverts. For inverts it should not exceed .01%
nipat
May 23, 2009
665
It is 0.05% by weight, not PPM.
Not a problem.
You know how much Cu in Plantex CSM+B?
0.1% :)
No Real Difference
herns;54695 said:
I found out there are two fert analysis to choose from.
Which one I would get?
Osmocote Plus 15-8-11
Osmocote Plus 15-9-12
The Osmocote Plus I use is 15-9-12, though the difference is not significant. :)
herns
Jul 29, 2007
287
The United States of America
Thanks.
Its frustrating that Home Depot and OSH close to my place doent not sell Osmocote Plus but only the regular one. (Osmocote). Got to find Lowes and TrueValue garden stores.
Left C
Sep 26, 2005
2,500
71
Burlington, NC
Yes, the plus is for traces.
burr740
Micros Spiller
Moderator
Feb 16, 2015
1,404
1,325
Wal-mart is the only place that stocks the Plus in my area. Home Depot/Lowes only have the regular.
