On floating roots and fertilization
Soggy
Jun 27, 2007
29
Does the amount of ferts we put into our tank determine whether stem plants form floating roots?
more specifically, has it been determined what causes stem plants to form floating roots?
Im curious because the rotalas at my lfs have very minimal floating roots while they root profusely in my tank. :confused:
I think it is a FACTOR, but not the direct cause.
I have seem many of my stems do this. I think it indicates good growth. The stems usually break apart at these rooted nodes to float away and form elsewhere.
Rotala, hygros, and ludwigia all do this profusely.
793
I've seen lots of roots in oligotrophic systems, eg Lake Tahoe, Lake Tamarack in the Sierra granite basins, plenty of of water column roots.
Far leaner than anyone's aquarium could even hope to be.
Most aquatic plants do this, Swords, Crypts do it, if they got roots, they put them out in the water column in most cases.
Healthy Indicator!
I have always taken it to be healthy growth. :)
That Is How They Roll
Soggy;43797 said:
but its so unsightly especially with ludwigias.
That is how Ludwigias roll, they are swamp plants most grow emerged, many for a reason call them Creeping Primrose, wherever a stem touches wet ground they send down roots and appear to ‘creep’.
Assuming your Ludwigias are Ludwigia repens, Red Ludwigia, they grow submerged and will happily grow right out the top of your tank, all the while sending bushy root on down from just about every node trying to get into the substrate. As the plant matures, the roots will be primarily from the lower nodes. ;)
Personally, I trim them so they grow in as bushes, anything you trim, you can, of course, replant the cuttings. Treating them as a group or bush takes the emphasis off the unsightly roots.:)
If you wish to have them grow up to or beyond the water line, plant a fairly tight bunch and trim regularly and it should grow into a really spectacular (with reasonable light) red and green bush.:)
