First of all, I'm not telling or suggesting to use more nutrients then EI recommends. I was only pointing out your error in confusing N (or NO3-N) with NO3 in your first post (and probably in designing your EI method as well). I know very well that in the Gerloff & Krombholz study they used diluted Hoagland's solution (200 ppm NO3, 50 ppm K, 20 ppm PO4, 40 ppm Ca, 10 ppm Mg, 0.4-0.8 ppm Fe etc.). This diluted nutrient solution is used very often for growing aquatic plants without a substrate media in hydroponics, so it's quite a standard. You know very well, that very often you say EI is supplying a non-limiting nutrient levels. So I wanted to point out, that it's simply not true. The non-limiting values would be the modified Hoagland's ones (200 ppm NO3, 20 ppm PO4 etc.), but not EI (30 ppm NO3, 3 ppm PO4). Again, I'm not telling we should use Hoagland's modified soup for growing our plants ... I just say, "EI is not non-limiting" (as you do say). So although it seems you based your EI metod on a wrong interpretation of Gerloff & Krombholz data, still I think the EI method is one of the best fertilizer methods suited for growing aquatic plants in our tanks, and if we combine it with any nutrient rich substrate, then we can supply our plants with nearly optimal nutrient levels for a maximum growth rates. I would like to point out also that according to my tests (and I believe I'm not the first one to find this) the plants use up only a relatively small fraction of nutrients from the external medium per week. So under 30 ppm NO3 in water column they may use up maybe 5-7 ppm NO3 per week, while under 10 ppm NO3, they will use up only 3-4 ppm NO3 per week under strong light and high CO2. So this seems to be another argument for why to use higher nutrient concentrations (like EI suggests) ... in case you want your plants to grow really fast.
PS: I did not find any reference in Gerloff & Krombholz paper (nor in the Hutchinson's book) as to how long did the test take.
