Solcielo lawrencia said:One graph can't include all factors. For example, temperature, nutrients, flow, etc.
kwisatz said:I think this graph would represent the nutrient concentration (uptake) with regard to growth rate much better:
This chart is not for any concrete nutrient. It is designed to show the general principles of nutrient concentration and growth. The numbers for nutrient concentration are just as example.
Tug said:Tom, I'm still reading the abstract.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CCgQFjAB&url=http%3A%2F%2Fwww.researchgate.net%2Fpublication%2F226747600_Interactions_between_light_and_CO2_enhance_the_growth_of_Riccia_fluitans%2Flinks%2F0912f50b79f5403c87000000.pdf&ei=n1alVMa6OYLhggS6-4PQDA&usg=AFQjCNGpb8LrlgWWIDvE0fOzewUbavJeIg&sig2=YdXZsAgp4IK_QDzEdrkuKw&bvm=bv.82001339,d.eXY
A good chance you are talking about these tanks at the AGA conference.
http://www.ukaps.org/forum/threads/co2-and-ei.35127/page-3#post-377272
Thank you everyone. Happy new year geeks.
No graph available.kwisatz said:I think this graph would represent the nutrient concentration (uptake) with regard to growth rate much better:
Any research? On this stage I'm not agree with this theory. But this is only my wisdom and experiences, no researches as "base".kwisatz said:...for most aquatic plants 20-40 ppm CO2 should be the optimum level (100% growth rate). At higher concentration the growth rate will decline...
The chart is just a general chart not meant for any specific nutrient (although it can be used for CO2 quite well). Still, the principle applies for all other nutrients, although each nutrient will have a different values (concentrations on the X axis), and a little different curve as well. But you should know that the CO2 concentrations (1mM = 44 ppm) was for a non-limiting environment. So in some limiting environment (like that in our tanks) the actual consumption (nutrient uptake) will be lower. So when aquatic plants under full sunlight (1500-2000 µmol PAR) grow at their maximum speed (100%) under 40 ppm CO2, then under 50-400 µmol PAR (the case in our tanks) they won't probably utilize such a high CO2 level. We limit the aquatic plants in our tanks in many way (not only by light). According to Gerloff & Krombholz, the most demanding aquatic plants (Ceratophyllum demersum, Heteranthera dubia, Elodea occidentalis, Najas flexilis, Vallisneria americana, Zannichelia palustris) need 21 ppm N (= 93 ppm NO3) to reach their maximal growth rate (100%). So by supplying them much lower level of nutrients we limit their growth in many aspects. And thus, they won't be able to uptake other nutrients in optimal way neither. So why would you supply your plants by 40 ppm CO2 (or even more) when you use 5-times lower light level, and 3-5times lower NO3 level then is needed for reaching the saturation point of photosynthesis?ak24 said:But nutrients is general, and one nutrient can do more than others in growth.
kwisatz said:OK, the chart I posted earlier can be seen here.
The "magic" value 44 ppm CO2 is propably also from the note of mine that according to many scientists most aquatic plants reach the photosynthesis saturation point at 1 mM CO2, which is 44 ppm. Actually, some aquatic plants reach the maximal growth rates at 0.5 mM (22 ppm). So it would be better to say that for most aquatic plants 20-40 ppm CO2 should be the optimum level (100% growth rate). At higher concentration the growth rate will decline (but not so dramatically as Tug suggests in his chart). But if you look at the chart of mine, for 90% growth rate you may need only 10-15 ppm CO2. I see no point in supplying more that 10-15 ppm CO2 other then lowering pH under 6.5, in which case some algae species would more readily die (e.g. Audouinella aka BBA, or Cyanobacteria aka BGA).
PS: Look at the Amano tanks in his "Nature Aquarium World - Book 1". You'll find that he used only 9 ppm CO2 (in average) in his 61 tanks. In one of his tank where he grew Rotala wallichii he used only 9 ppm CO2. Think of it.
Marcel
kwisatz said:So why would you supply your plants by 40 ppm CO2 (or even more) when you use 5-times lower light level, and 3-5times lower NO3 level then is needed for reaching the saturation point of photosynthesis?
This argument is really good if we speak about plants, but not as good if we speak about fish and/or shrimps. I agree that when we measure 40 ppm right under the water surface level, in the plant beds we can have hardly 15 ppm CO2. That's one of the reasons why a good flow is so important in planted tanks. On the other hand (if I understand it correctly), you keep 50-70 ppm CO2 in your tank just because you want higher (maybe ~30 ppm) levels at the hard-to-reach places. Although I understand it from the perspective of the plants, I think it's very insensible from the perspective of the fish/shrimps (especially the fingerlings).Tom Barr said:Because I'll get algae otherwise.....
I do not assume that 40 ppm of CO2 or 20 ppm of CO2, or 9 ppm of CO2 is "good, ample, non limiting".....
The methods used for the research: ..... The biomass is very low, flow is good. As you increase biomass, within the plant groups, the CO2 drops.
We measured 45 ppm near the inflow, then added a lot of Egeria Densa, about 50 stems and roughly dense 18 inch ball. The CO2 inside in the middle was only 15 ppm.
And if you have algae under lower CO2 levels, are you really sure it's CO2 issue? How do you know that?
I have read that many asian master chefs will teach you how to slice and dice the food in proper fashion but never give away there true recipe.Tom Barr said:Amano fudges his parameters(or whoever wrote those parameters), there's no way they are all so close.
And the KH/pH chart woukld have to be incorrect in an impossible way to have those ranges of CO2.
