Nu Clear Canister filter with pleated cartridges
Discussion in 'Trades, swaps, sales' started by Tom Barr, Oct 10, 2015.
  1. Tom Barr
    18,693
    726
    5:53 PM
    I have a pretty new shape Nu Clear filter with the 20 micron pleated cartridge and I have a spare couple of cartridges also. Shipping will cost more if you want them all(2-3 extras, likely another 20$ extra), vs just the canister and the cartridge inside with the fittings(90$ shipped).
    But at 40-50$ ea cartridge, it is a good deal.
    For those who do not know much about these, they require a pressure rate pump, that's not included.
    They are good for high volume micron filtration.
    [​IMG]
    Also, a nice Maxspect LED unit, Mazarra P. Good for a 120 Gallon, there are two lights, these run 500$ each on line and then the other items cost extra, the total is 600$ shipped, you get 3 of them with remote ballast, but one row of the whites flashes on one of the units, the other 2 are fine, you likely can fix it. A client removal, so this one is priced low to move it. 1500$ new. 600$ shipped. You could use one on a cube and then the other on another cube tank etc. I think you can also remove the LED's and swap with something else more specific if you wanted to.
    [​IMG]
    More info one them:
    http://maxspectusa.com/index.php?option=com_content&view=article&id=1&Itemid=2
    Also 2 left, 2.5 lb CO2 gas tanks. 50$ each. Aluminum and date stamped for several years.
    [​IMG]
