Not new to aquatic plants but.....
Discussion in 'Are you new to aquatic plants? Start here' started by cuban007, Jan 24, 2015.
  1. cuban007
    cuban007 Junior Poster
    Jan 24, 2015
    15
    4:25 PM
    I am not new to aquatic plants but I have never used CO2. I would like to start using CO2 in my tanks. I have a 55gal, and a few that are 20g and 40g. Any tips on cost and installation??? Thanx.
  2. krucianking
    krucianking Junior Poster
    Feb 8, 2015
    4:25 PM
    I am a newbie to this site but a good co2 setup sets you back about 250 bucks
  3. gerryB
    gerryB Junior Poster
    Feb 8, 2015
    4:25 PM
    Yes, I agree with the $250 number as well. Your bigger expenses will be the initial cost of a cylinder (5lb maybe around $70-$80), and a decent dual stage regulator with a solenoid (ballpark $130+). You will also want a bubble counter (if not on regulator, not too much, and can DIY), a check valve, and CO2 resistant tubing. Of course, the gas isn't included in the cylinder - in my experience they run around $20 or so. You may be able to start off cheaper with 'paintball' type setups, but I wouldn't recommend this with your tank sizes. I use 5 lbs. cylinders myself.
  4. cuban007
    Jan 24, 2015
    15
    4:25 PM
    Thanx for the info.
  5. Melissa Morrison
    Melissa Morrison New Member
    Feb 12, 2015
    12
    4:25 PM
    I know it is expensive to set up a new CO2 system (the cost of the tank and the regulator alone are quite pricey). However, take my advice and don't skimp on the diffuser/reactor like I did when I set mine up the first time. In the end, it is not worth it just to save a few bucks on the diffuser, because you won't get the results you are looking for if you are losing most of your CO2. Get a really good quality diffuser/reactor (or better yet DYI one with PVC for larger tanks) so that you get as close to 100% of your CO2 being dissolved into your tank water as possible. The fewer CO2 bubbles that escape to the surface, the better! And it saves you money in the long run when you don't have to fill up your tank as often.
    #5 Melissa Morrison, Feb 12, 2015
  6. Lksdrinker
    Lksdrinker Junior Poster
    Feb 13, 2015
    7
    4:25 PM
    If you're not in a hurry keep an eye out on CL and all the various forums for used equipment. I hardly ever pay full price for any aquarium equipment anymore as there always seems to be someone selling something I need at quite a discount compared to new! So long as you dont simply buy without checking the item out you should get a good working piece of something for a fair deail.
  7. Freemananana
    Freemananana Junior Poster
    Feb 19, 2015
    6
    4:25 PM
    I definitely agree with picking up second hand stuff. I would stick to forum for sale sections though.
  8. jard
    jard New Member
    Feb 28, 2015
    7
    4:25 PM
    I agree with what Melissa said. I started with a good CO2 regulator + tank but I skimped on the CO2 reactor which reduced the effectiveness of injecting CO2. The DIY reactors are pretty affordable and effective. I think it pays off to not rush setting up you aquarium, so I would recommend looking at some of the DIY options and spend an extra week or two sourcing the parts and putting together a proven reactor.
  9. jeff123
    jeff123 Junior Poster
    Feb 27, 2015
    15
    4:25 PM
    Hi. This is my 1st post. Since I am from Asia , that my case might not apply to you guys. Bought a Ista co2 system with solenoid. The tank is shiny that is all. But controlling it is other matter. I am regretting it now should have bought an industrial one. Slight price higher here but less headache...
  10. shoggoth43
    shoggoth43 Lifetime Charter Member
    Jan 15, 2009
    4:25 PM
    Don't forget that some of what we play with you can find in home brewing or other applications. However "Kegerator" or "Aquarium" means specialty and that can mean serious money. Industrial is usually quality stuff as there's not a lot of market tolerance for blowing up your clients. For freshwater applications there's little need for stainless either so that's more money you can put towards other things.
