Nonlimiting Nutrient Info Request
Philosophos
1,346
Hey everyone, I'm just looking for some good studies showing situations with nonlimiting nutrients that distinctly do not induce algae. I could pick through the google pile, but I'm sure enough of you have bookmarks handy. Reading through studies to find a noted lack of algae is a bit of a PITA.
I'd be happy to return the favor should anyone else ever be looking for information I've got that's time consuming to search for.
-Philosophos
With aquatic plants or?
Bachmann, Crismann, Hoyer etc for Florida is where you might find the most info, not much has been done really, it's not much of an economic applied issue.
"Critical concentrations"
Gerloff 1966 etc
Will help.
Philosophos
1,346
I was hoping for some ex situ kinda stuff just to show the principles of non-limiting nutrients/CO2 as detailed studies. So far what I'm finding is mostly phosphate related eutrophication related stuff.
Still, the key words you gave me ran me into Mark Hoyer's page on U of F's IFAS site and a pile of his work. I'll leave the link for others who happen by this thread:
Mark V. Hoyer
-Philosophos
Well, there's no correlation in natural systems, that are shallow, planted, with submersed plants etc from low to high nutrient ppms for N or P.
Bachmann's et al 2002 paper clearly showed this with a 300-400 lake survey where plants are present.
If no plants are present, I think water ppm's for N and P will correlate with algae pretty well.
US 2 Cents
Hi Philosophos,
My generally useless $US .02. :p
I suspect that, as with many things in the planted aquaria world the data are just not available. As Tom Barr said no money in planted aquaria research, wetlands preservation, restoration, weed control, water/wastewater treatment and so forth, big $US, planted aquaria, low rent, niche hobby at best. ;)
If we want data, we gonna have to produce that data and when I say we, I really mean you. :rolleyes:
All seriousness aside, it is up to those interested to do and/or fund the research and most of it is just one plant, one species at a time day in day-out, totally unglamorous, observation.
Philosophos
1,346
I was hoping some ecologist or other would be interested in eutrophication enough to have tested all of this outside of a lake. It would make sense to pull various elements apart, deconstruct them, and figure out basically how to build a lake in order to understand it better.
I'd do the whole works right now if I had the equipment and funding. As it is, I've got other experiments that meet my budget right now... as soon as I get my drop checker back from someone who's borrowing it.
Speaking of which, that experiment got somewhat off the ground before I lent out the drop checker. Early tests are looking like CO2 in the tank looked about the same after 5 days when undisturbed as they were with an air stone constantly. Before that, the levels were lower and far more inconsistent. This is an experiment I'm going to be coming back to re-do with the drop checker, and likely again in the future if Tom's pH probe CO2 meter concept becomes something I can get my hands on. Again, time and money for that one.
-Philosophos
Eutrophication, Spell-Checker Don't Like
-Philosophos
Hi Philosophos,
I think one problem with studies of lakes and wetlands as far as I can tell is the systems are far more open than our little tanks and with computer modeling, I suspect it is pointless.
One small point to consider is the water movement, we turn the tank water volume over 15 or 18 times and think it a lot, you read the folks afraid that at 25 times turn over, their plants and fish will be ripped to shreds. :)
Then calculate a lazy half knot or knot stream or lake circulation and see how many times you would need to turn the tanks water volume. I have set up a couple of raceways and it is interesting.
Then the other difference eutrophication in the world is generally a result of non-point sources of nutrients, whereas ours is distinctly point sources of nutrients.
Your drop checker dilemma; I have found multiple drop checkers handy, even with my new gizmos. ;) I use test tubes and a hunk of tubing, that way I can monitor any number of locations simultaneously.
If you have, a Fry’s Electronics around they have cheap 25 or 30 ml, el–cheapo test tubes. I love this set up because I can stick the tubes in groups of plant high and low. They even work for the ‘instant read’ versions using gas permeable membrane, such as the inside of mailers you can obtain from mailboxes almost anywhere. :eek:
The lab vs the bench scale vs the field test vs the natural systems, WHERE plants are present, and your management goal is providing good growth and that you plan to also prune and maintain the biomass( a huge labor given that they are weeds).
Sort of specific.
I sort of doubt ecologist, limnologist really are that interested in artificial aquarium systems that grow aquatic weeds.
Unles sit's for agriculture/aquaculture, some $$$ involved, not really.
For lakes, they want clear water and no labor to maintain it.
So weeds choke things, and algae gives pea soup, there's not that much in between.
Weeds or pea soup.
I think management wise, draw downs beat the weeds back each year good, and make the labor easier.
Some spray herbicides to beat them down.
Some just watch and observe as the weeds take over and choke everything.
Then cry about who if they'd only known when it was just a little problem(classic invasive species manta, hindsight is always 20/20)
I think you will find that isolation of the components is tougher than you might think. They need to be all together to work like a real system(aquarium or a lake etc).
I can induce GW in some systems, but not others using NH4.
Higher light is more sensitive to changes than say low light, some plants are more touchy than others etc. CO2 factors........water changes, filter flow.
You can vary these and build on them using the others independent of the dependent variable/s.
Few have such control unfortunately(many like to think they do, but do not verify that they in fact do, then rush to conclusion without being sure of that, thus make the mistake). I'm just not that sure.
I know what it cannot be under some conditions.
That's about it.
Folks think I know a lot, but really? Not much.
Philosophos
1,346
Okay, so I can scratch the idea of finding good research on non-limiting nutrients for now.
It's a shame limnologists are so interested in killing all of this stuff off. I know in some cases it's for the sake of the ecosystem, but so often it also seems to be for the sake of recreation. I guess it's all a matter of who's signing the paychecks.
It's too bad that aquatic plants have nothing like the Axelrod's to lay foundation work. It seems that any large quantities of money involved with this hobby keeps the research to its self for the purposes of marketing products.
I'll keep plugging away then.
Tom, you know tons compared to most of us. You're just very critical of what you know, which is something I can not say the same of for everyone. It's a good quality; it keeps your posts encouraging others to look to the next step rather than drawing conclusions too early. Sometimes it pisses us off when we just want an answer, but I know I'd rather have an honest "It depends" or "I don't know" than some sort of fabricated tautology.
-Philosophos
Well, limnologist/phycologist/botantist are not focused exclusively on killing the stuff off, rather, seeing how their research can be used to manage it and understand it.
They get some basic science, relationships etc along the way and they(folks wanting to manage) do fund research;)
So practical applied problem solving is more what they do.
No one is just going to give you $ to play around with little applied practical use.
A few curious planted aquarist really does not constitute a particularly large market nor a source of funding:cool:
That is the way it is.
Commercial aquatic plant growers need no such research either, they are more worried about temps, sales, new species, day to day business operations, they already can grow tons of plants without issue at very large scales, they are weeds after all.
While a noble question, few have understood why it has not been answered.
Some evidence might come from the FL Everglades research groups with periphyton. Not submersed systems in most respects(aquatic tend to be all emergents 40-80% of the year).
Even making controls in aquariums is tough.
Peixetos
Aug 6, 2008
7
Vienna (Austria)
A point of view of someone who lives far from the sea: where is more pleasant to swim in summer, on a clear water lake with gravel in the bottom where you see where you go or in a dark green water lake where you can't see the aquatic plants you contact by swimming? I can say by experience that aquatic plants on bathing places are not very pleasant...
Well, I like clear water and plants:
Above the water:
Search Bonita Springs, in the Mato Grosso
San Macros River TX, Rainbow River FL,
Pupu Springs NZ etc.
Plenty of nice examples, however, a weed choked lake is hardly any fun to swim in! That I do agree.
Philosophos
1,346
I grew up near a large lake with plenty of weeds, but also clear water. I noticed the diversity of life on those weedy mud or rock bottomed beaches far surpassed the average groomed beach. Guess which ones I liked best? ;)
-Philosophos
Water Turnover
Just look at the water flow. :eek:
I grew up in a swamp (bog now days), in an area with lots of lakes and streams and one thing I remember is the best places had water movement. :rolleyes:
I think if you saw this you'd think differently of aquatic plants in natural locations:
No one would want to boat or swim there, even though the water is fairly cleaned by all the hyacinth. Few fish can survive under these mats since O2 is extremely low.
How do you keep say 30% of the surface covered without a massive amount of labor for this weed?
The answer is that is depends.
This is here I get my soil for aquatic weed experiments in the CA Sac/San Joaquin river delta.
Rooted submersed, floating, and emergent weeds. Decades of control programs, Millions upon millions spent, lawsuits all over the place, dozens of stakeholders with all different agendas about how/what to do with the water, weeds etc.
Yes, it's quite the "stew":cool:
Anyone want 20 Acres of Cabomba?
I'm serious.
BTW, the bottom pic is before applying 2,4 D, the top is regrowth a month after spraying it, the weeds come back even with herbicides. They hit it again, but still did not get it all.
Hard to kill this plant, Biocontrol will not work in CA, the bugs cannot reproduce and cannot be grown on artificial media.
Works fine in Lake Victoria Africa etc, but too cold and dry here.
But the plant grows so fast, it clogs the water ways for boaters and fishing folks.
Imperils native species many of which are endemic.
Water is nutrient rich due to agriculture run off for the entire central valley of CA drainage, good CO2 and flow due to tidal pull 2x a day of several ft, nice clay soil good for growth of most plants.
I swim in the American River myself and run along it's pathway. It got lots of weeds but it is very clear also.
Philosophos
1,346
Water hyacinth is nasty stuff... that's just obscene though. I can see where you'd want to kill it off though, and some of the hindsight commentary. So often invasive species caused by human introduction or interaction seem to make things far more difficult. Some of the cures involving introducing yet another species seem to have equally horrendous effects.
I think you'd have to pay me to take 20 acres of cabomba though; it's had about the same appeal as hornwort or Eurasian milfoil to me. All three spell out glorified goldfish food to me. I'll take that stand of river choking ludwigia though :rolleyes:
Just because I'm curious; does the spread of invasive aquatic plants ever happen naturally? So often humanity is blamed that it starts to sound as if humanity is the only time nature created a problem with an invasive species on its own.
-Philosophos
nipat;43256 said:
I'm sure there are dozens of locations in China, and dozens of other countries with loaded springs full of plants.
Same for Australia, etc.
It's a universal beautiful habitat for submersed aquatic plants.
Unfortunately, examples of weed infestations are much more common and cover far more acres.
The Hyacinth in the Ca Delta is just one tiny side arm picture, there are miles and acres of the stuff, and it dies back strongly due to cold temps each year, but then regrows from the stumps to full glory in a few months when it starts getting warmer.
It's taken years to beat the weed down to manageable levels just so folks can get boats, water skiing, fishing, transport, irrigation and drinking water, endangered species protection etc.
Egeria, Eurasian Milfoil and Cabomba are the worse submersed invasive species, All except the Crispy Pondweed, are native Potamogeton species, many are very pretty. Hornwort is also "native".
Crispy pondweed is pretty bad and hard to get rid of, they have that up in Lake Tahoe, along with Eurasian milfoil. Unlike the CA Delta, Lake Tahoe is very oligotrophic and very cold (but does not freeze over).
We find it there due to the Boaters not cleaning their boats, dragging it back to Tahoe Keys marina. Very different system, similar weeds and similar vectors spreading it.
You cannot use any herbicide for management in Lake Tahoe however.
So they pay divers and locals to hand weed. Needless to say, not that effective/ or more like, simply fruitless.
They also will not allow dredging, so they are doing nothing basically.
Welcome to world of aquatic weeds:)
But they allow oil leaking boats, jet skis etc(all leak some oil), they allow unfettered development and thereby run off into the lake............that is "okay", but not any other management of this so called protected pristine system:rolleyes:
