Hi all and especially hi Tom
long time no see!
I am now very much into reef aquariums and am trying to understand what induces algae and dinoflagellates in marine/reef tanks.
I am running one Red Sea Max 130 litres Soft coral reef for 2 years now, where I do 3 (25%) water changes per, never dose any extra Ca, Mg, Alk, traces... nada! I only feed fish with Artemia/Mysis and top-up the system with Osmosis water.
All corals and fish are thriving and growing.
I get no algae problems of any kind despite the VERY High NO3 and PO4.
NO3 at (over) 100ppm (Salifert test)
PO4 at 4ppm (Salifert tets also re-tested with Elos both tests showed high PO4)
Ca at 400-410ppm
Mg at 1240 ppm
KH at 9
pH at 8.2
temp 25'C
Salt used for water change Instant Ocean (low in Ca, Mg)
I am not debating NO3/PO4 damaging SPS/LPS corals or even making them look brown due to Zooxhantelle development.
All I am saying that NO3 and PO4 do not cause algae blooms in marine/reef aquariums otherwise my tank should be a Green Soup
If not NO3 and PO4 then what induces algae in marine environments???
Is it low O2, low Oxidation-Reduction potential, low level of CO2, low levels of Amino-acids maybe, or even proteins (which are removed via Skimmer and wc), low levels of trace elements, etc...
I have seen many reef tanks with no NO3 nor PO4 and still they get algae (or/and dinoflagellate) problems.
I started a new 180 litres Soft coral reef and for 3 month I had NO3 0ppm and PO4 0ppm. I have problems with Green Dust Algae on the glass. The algae behaves the same as the freshwater GDA. I scrape it off and it attaches it self to glass after just couple of hours.
Just a day ago I started dosing KNO3 and KH2PO4 to the system and will try to get the N and P up a bit and see how that works.
Can anyone help in resolving this mystery please
Thanks a million!
Regards, Dusko
Ca at 400-410ppm
Mg at 1240 ppm
KH at 9
pH at 8.2
temp 25'C
Thanks a million!
Regards, Dusko
