No bubbles when solenoid cuts on
Discussion in 'CO2 Enrichment' started by Firstman, Sep 25, 2009.
  1. Firstman
    Firstman Junior Poster
    Oct 3, 2008
    10
    8:44 AM
    Hi all,
    I just received a used Milwaukee ma957 w/solenoid. Followed the instructions I found online and set it up. I am having trouble with no bubbles coming out when the solenoid cuts on in the morning. If I adjust it so that I get bubbles, then they won't stop coming out when solenoid cuts off. I have had (1) day where everything was ok. Cut on/off as supposed to and was happy. That was yesterday. And now today no bubbles this morning again. :mad:
    Short version of what I am doing:Open regulator knob valve fully, open main tank valve fully, plug in solenoid, open needle valve, close regulator knob to approx. 10lb., unplug solenoid, attach tubing, plug in solenoid, and adjust.
    Seems simple enough. As I am adjusting I can unplug the solenoid and the bubbles stop. Plug it in and they start again. Come in the next morning after they were supposed to be on for an hour. Nothing. I have almost had enough already.
  2. abcemorse
    abcemorse Prolific Poster
    Sep 8, 2008
    83
    8:44 AM
    I have the same setup, sounds like either the solenoid is bad or the needle valve is malfunctioning. You can take the needle valve off and clean it out real good, if that doesn't help try turning pressure up to 30 psi or so, mine seems to work more consistently at that pressure, although it's still not great:mad: I'm looking into the Sumo set up, put it on the Christmas wish list, we'll see how that goes...:D
  3. Firstman
    Oct 3, 2008
    10
    8:44 AM
    I am new to pressurized CO2. How do you clean a solenoid?
  4. abcemorse
    Sep 8, 2008
    83
    8:44 AM
    Sorry, I was unclear, clean the needle valve, not the solenoid. If the solenoid is bad you pretty much gotta replace it. The needle valve can be cleaned by running it under water, blowing in it, maybe a gentle cleaning with small guage wire.
  5. scottward
    scottward Guru Class Expert
    Oct 26, 2007
    958
    10
    8:44 AM
    Also have a look at your non-return valve (possibly integrated with the bubble counter). I had a problem with mine whereby no bubbles would come on when the solenoid kicked in. Turns out that the non-return valve was clogged up.
    I'd actually be pretty sure that this is what it is - try bypassing it temporarily just as a test and see if gas flows.
    Scott.
  6. scottward
    Oct 26, 2007
    958
    10
    8:44 AM
    How did you go?
