Hey All,
I recently got a pressurized co2 system and ferts for my 25 gallon planted tank. I have been using PPS Pro daily dosing, but have run into a few issues with some plants.
Here's an overall shot of the tank. Its my first tank and I know it sucks lol:
Quick Stats:
Tank: 25G (24x13x19)
Substrate: Soil with Cap
Lighting: Finnex Ray 2 DD (7000k/10000k LED's) 18" from substrate to fixture
Micro Mix: Millers
Ammonia: 1ppm (never seems to go below this on ANY of my tanks?)
Nitrite: 0
Nitrate: 30ppm
PH: Tap(7.5), Tank(6.6 with co2)
KH: 3d
GH: 5d
Temp: 78-82 F
First, I had creeping jenny which was growing taller, but had melty spots on all of its bottom leaves.
Next, my micro swords are curling and browning. may even have slight diatom coating, but I'm not sure. Some of the brown looks "caked" on and rubs off.
My L Repens has some pretty red top leaves, but the bottom leaves are discolored and growing a lot of GSA:
Lastly, I was told this is normal, but the new growth from my swords have reddish/dark veins. They are supposed to be normal growth, though?
As you can see, my two GIANT swords. They started off the size of my hand, and have now grown to epic proportions in a matter of months. Could they be draining some nutrient from the water and not leaving enough for other plants, since I'm using PPS Pro and not EI? Should I switch to EI? I was thinking of dosing more K, as I've read you can't really overdose K, and its something plants use a lot of. Should I?
One other issue. I did a phosphate test today, and had very, very high levels. Around 9-10ppm.
Thanks for any help you guys can provide. I'm loving this hobby so far, but ferts are confusing :|
Quick Stats:
Micro Mix: Millers
Nitrite: 0
Nitrate: 30ppm
KH: 3d
GH: 5d
Temp: 78-82 F
