Hi guys,
I'm looking to have a new tank built and the clossed loop method of filtration is very appealing to me. The tank will be 110cm x 55cm x 50cm, but I may change these measurements if you guys suggest better measurements to get a better visually deep looking tank.
With filtration, how many holes should I have drilled into the bottom of the tank and what size bulkheads? I want to run CO2 inline and a heater as well. I have an Aquamedic oceanrunner PH2500 needle wheel from my 120 that just cracked
, I'm unsure if I could run this PH inline and whether I'd require another hole to be drilled for it. For filtration I'm thinking FX5 as they are readily available and the larger ehiem classics are nowhere to be found.
What do you guru's think about it? Any plumbing suggestions or overall suggestions?
Cheers,
JK
Cheers,
JK
