hi all,
I am getting finally my new tank ready to use!
I am using ada aquasoil for the first time. I placed it on the bottom of the tank an gently filled the tank. The plan is to let the (excess) ammonia from the aquasoil leak into the water while the tank is not really up and running (no plants no lights). I decided to do this simply because I don't have the capacity to produce the amount of osmosis water needed for the reommended 80% waterchanges 3-4 times a week.
I wondered how much ammonia ada aquasoil leaks into the watercolumn. can you get actually high readings on an ammonia test kit? Will I have to do the procedure for one month? or will 2 weeks be enough to get rid of most of the ammonia?
Also, when I move the aquasoil by hand, the tank get's really really cloudy. will this occur every time when I move the aquasoil? Since I am planning to do a semi dutch tank (I am from holland
) this will involve a lot of pruning, moving plants and will for sure cause movement of the gravel. I would like to avoid a cloudy tank every time I uproot some plants. Is there anything I can do about it? can I gently lift the top layer of aquasoil to get the dust away? (and than do a couple of waterchanges). or will I just smash the aquasoil into little particles and wil I get nothing but mud?
thanks for any help!
yme
yme
